Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
25 Oct 2021 03:35 #224176
Replied by rodw on topic Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
ModuleNotFoundError: No module named 'qtpyvcp_conversational_gcode'
25 Oct 2021 03:44 - 25 Oct 2021 03:45 #224178
by spumco
Replied by spumco on topic Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
Thanks for taking a look Rod.
I did install the conversational-gcode git. Running it again:
mill@MILL:~/probe_basic
$ git clone git://github.com/kcjengr/qtpyvcp.conversational-gcode.git
fatal: destination path 'qtpyvcp.conversational-gcode' already exists and is not an empty directory.
Do I need to add something to a path?
Last edit: 25 Oct 2021 03:45 by spumco.
25 Oct 2021 03:56 #224185
You arlready have stuff in that folder so git will fail like that so you should do a Git Pull instead.
25 Oct 2021 04:04 #224188
by spumco
How do I do a Git Pull?
25 Oct 2021 04:29 - 25 Oct 2021 04:38 #224194
by spumco
Got it.
Not really sure how, but I think the conversational repo in the original post was pointing to the older python2 version. Once I cloned the python3 branch directly from the github page and re-ran the python3 pip install everything cleared right up.
-R
EDIT - I knew this was too easy. Now I'm getting an unexpected realtime delay error 5 seconds after probe basic starts up.
I hate clogging up an installation guide thread, but here's the terminal output:
Unexpected realtime delay on task 0 with period 100000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
[qtpyvcp.plugins.notifications][ERROR] Unexpected realtime delay on task
This Message
session.
resolve before continuing. (notifications.py:139)
-R
This Message
session.
Last edit: 25 Oct 2021 04:38 by spumco.
25 Oct 2021 05:59 - 25 Oct 2021 06:05 #224214
by spi
Replied by spi on topic Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
Like you've already noticed it's important to check out python3 branch. I included it as a separate git checkout python3 command so that it's cleaner to remove once the master branch is Python 3.
Judging by the error message "ModuleNotFoundError: No module named 'qtpyvcp_conversational_gcode'"
Please check you haven't missed these steps:
cd ~
python3 -m pip install --editable .
You can also run 'pip3 list' to check conversational gcode is installed.
Note that in my guide cd ~ is missing as it's better to clone conversational gcode to home directory.
cd ~
Last edit: 25 Oct 2021 06:05 by spi.
25 Oct 2021 06:02 #224216
by spi
I also see the same error with realtime delay on task 0. Unclear why that would be.
- davidimurray
- Thank you received: 5
25 Oct 2021 09:14 #224241
by davidimurray
Replied by davidimurray on topic Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
Thanks SPI for this - it's great.
I found the issue with Probe-basic not showing up in the start list. It is because linuxcnc installs into a folder called linuxcnc-dev but probe-basic installs into a floder called linuxcnc. Copying the config files from linuxcnc to linuxcnc-dev fixed the issue.
25 Oct 2021 09:30 #224242
by spi
One more difference that I found is that in LinuxCNC help the configure step is run adding the parameter:
--with-realtime=uspace
That might explain the error and be more correct anyway. I'll add to the guide once I get the formatting sorted out.
25 Oct 2021 11:36 #224247
by spumco
Have you tried running a machine or the latency tests while getting the error? I am reluctant to just ignore it, as I suspect it's something to do with this MX21/LCNC2.9/qtpyvcp/probe basic installation. I never had a latency error after under 2.8 and the older versions of qtpyvcp and probe basic.
Time to create page: 0.362 seconds
