Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
27 Oct 2021 15:57 #224524
by Flyer007
Replied by Flyer007 on topic Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
figured out the menu item. Never did a RIP install. got it
27 Oct 2021 19:11 #224531
by spi
Replied by spi on topic Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
Thanks for the comments! I guess my guide assumes you're starting from scratch so the folders wouldn't exist then. I edited the guide to add the cd to conv gcode folder.
27 Oct 2021 19:13 #224532
by spi
@zhult Can you please post the output of 'pip3 list'?
28 Oct 2021 11:11 #224563
by zhult
Replied by zhult on topic Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
here is my pip3 list
28 Oct 2021 11:59 - 28 Oct 2021 12:08 #224568
by spi
qtpyvcp should report version 0.4.0 in pip3 list.
Please try running through these steps again:
cd qtpyvcp
featherpad setup.py
Enable line numbers in: Options-> Line Numbers
Modify line #62 to version='0.4.0',
python3 -m pip install --editable .
cd qtpyvcp
featherpad setup.py
Last edit: 28 Oct 2021 12:08 by spi.
28 Oct 2021 14:28 #224582
by Flyer007
"Run LinuxCNC
~/linuxcnc-dev/scripts/linuxcnc"
Step.
I did start from scratch. The directories seem to be created in theThanks for the comments! I guess my guide assumes you're starting from scratch so the folders wouldn't exist then. I edited the guide to add the cd to conv gcode folder.
"Run LinuxCNC
Step.
28 Oct 2021 16:40 #224594
by spi
Good catch! Maybe the two mkdir commands are superfluous then!
28 Oct 2021 21:44 #224615
by zhult
I did fix the issue in the pip3 list. I still have an issue i think with the conversational as i am still getting the Base op error. i uploaded the pip3 list and the error long.
29 Oct 2021 06:22 #224628
by spi
Are you sure you checked out the python3 branch of conversational before installing?
29 Oct 2021 11:53 #224642
by zhult
from what i followed yes i think i did. but im new to this so i could have easily missed something. I went back to that section of the guide and found a warning.
WARNING: Error parsing requirements for qtpyvcp-conversational-gcode: [Errno 2] No such file or directory: '/home/zach/.local/lib/python3.9/site-packages/qtpyvcp.conversational_gcode-0.0.1.dist-info/METADATA'
Time to create page: 0.123 seconds
