Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
25 Oct 2021 11:38 #224248 by spi
What kinds of results your latency test gives?
~/linuxcnc-dev/scripts/latency-test
My newest box is not giving the error anymore after configuring linuxcnc with the --with-realtime=uspace option.
25 Oct 2021 12:55 #224256 by spumco
I don't remember the exact number, but latency was 'acceptable' for a Mesa card setup if my interpretation of the various latency discussions is accurate.
I'd like to try the lcnc configuration you've mentioned.  Do I just start LCNC with "--with-realtime=uspace", or is there something else I have to install/modify?
25 Oct 2021 13:02 #224258 by spi
Please check my updated guide but basically you need to do this:
cd ~/linuxcnc-dev/src
./autogen.sh
./configure --with-realtime=uspace
make
sudo make setuid
25 Oct 2021 13:05 #224259 by spumco
Thanks for the clarification.
Would you suggest uninstalling LCNC, qtpyvcp, and PB before re-installing LCNC with the new --with-realtime=uspace option?
Or should I just re-run everything (or some part) from your guide and what needs to be overwritten will take care of itself?
25 Oct 2021 15:06 - 25 Oct 2021 15:07 #224273 by PCW
Unexpected realtime delay on task 0 with period 100000
The servo thread rate should be 1 KHz normally ( period 1000000 ns).
It looks like you have it set for 10 KHz which will not work with most hardware.
Last edit: 25 Oct 2021 15:07 by PCW.
25 Oct 2021 15:11 - 25 Oct 2021 15:14 #224274 by spumco
Where is that set or adjusted?  Keep in mind that this installation is unmodified from the OP's first post - I haven't started setting up my actual machine other than ensuring that mesaflash can talk to my 7i76e.
EDIT - in the ini file, under EMCMOT, right?  If so then it looks like the Probe Basic sim is defaulting to 10KHz and this should clear up once I copy over my working config.
Last edit: 25 Oct 2021 15:14 by spumco.
25 Oct 2021 16:05 - 25 Oct 2021 16:07 #224277 by Roguish
yes, in EMCMOT.
from the manual: SERVO_PERIOD = 1000000
the sample configs, particularly the new ones like QtPyVCP, could be suspect. MOST important is to RTFM.
stepconf and pncconf are intended to be helpers, not end-alls.
recommend going through the config files line by line with reference to the docs, to learn and understand what's going on.....
good luck.
Last edit: 25 Oct 2021 16:07 by Roguish.
26 Oct 2021 03:37 #224320 by spumco
Following the updated installation guide did the trick.
No errors, no problems, no headaches.
Thank you!
The following user(s) said Thank You: spi
27 Oct 2021 03:34 #224464 by zhult
Hello all. im a new user to linux and i was following this guide to get Probe basic to work for my Mill im building. I got to the end of the guide and have some errors. Any help is very welcome. Thanks
Traceback (most recent call last):File "/home/zach/.local/bin/probe_basic", line 33, in <module>sys.exit(load_entry_point('probe-basic', 'gui_scripts', 'probe_basic')())File "/home/zach/probe_basic/probe_basic/__init__.py", line 20, in mainqtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)File "/home/zach/.local/lib/python3.9/site-packages/qtpyvcp/__init__.py", line 27, in run_vcprun(*args, **kwargs)File "/home/zach/.local/lib/python3.9/site-packages/qtpyvcp/app/__init__.py", line 129, in runlaunch_application(opts, config)File "/home/zach/.local/lib/python3.9/site-packages/qtpyvcp/app/launcher.py", line 78, in launch_applicationloadWindows(config['windows'])File "/home/zach/.local/lib/python3.9/site-packages/qtpyvcp/app/launcher.py", line 228, in loadWindowswindow = _initialize_object_from_dict(window_dict)File "/home/zach/.local/lib/python3.9/site-packages/qtpyvcp/app/launcher.py", line 203, in _initialize_object_from_dictobj = _get_object_by_referance(provider)File "/home/zach/.local/lib/python3.9/site-packages/qtpyvcp/app/launcher.py", line 191, in _get_object_by_referancereturn getattr(importlib.import_module(modname), attrname)File "/usr/lib/python3.9/importlib/__init__.py", line 127, in import_modulereturn _bootstrap._gcd_import(name[level:], package, level)File "<frozen importlib._bootstrap>", line 1030, in _gcd_importFile "<frozen importlib._bootstrap>", line 1007, in _find_and_loadFile "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlockedFile "<frozen importlib._bootstrap>", line 680, in _load_unlockedFile "<frozen importlib._bootstrap_external>", line 790, in exec_moduleFile "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removedFile "/home/zach/probe_basic/probe_basic/probe_basic.py", line 13, in <module>from . import probe_basic_rcImportError: cannot import name 'probe_basic_rc' from 'probe_basic' (/home/zach/probe_basic/probe_basic/__init__.py)
27 Oct 2021 14:14 #224520 by Flyer007
Has anyone tried this with the Wildfire release? I am having some issues.
Also there are some steps in directions that seem off.
at cp ~/qtpyvcp/scripts/.xsessionrc ~/  I have to use full path for it to work
Then
mkdir ~/linuxcnc
mkdir ~/linuxcnc/configs
Error out as the directories are already there
Lastly;
git clone git://github.com/kcjengr/qtpyvcp.conversational-gcode.git
git checkout python3
you need a cd qtpyvcp.conversational-gcode before checkout
When I finish, I can start linuxcnc from terminal  I don't see anything in the MX start menus for linuxcnc only QT designer
I was able to get PB sim to load once.  I don't see any PB_Lathe in the linuxcnc selection list
Moderators: KCJLcvette
Time to create page: 0.181 seconds
