Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
11 Jan 2022 15:52 #231454
by scotth
Replied by scotth on topic Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
Could you post your .ini file? I would like to see the working version.
11 Jan 2022 22:36 #231494
by cmw
Replied by cmw on topic Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
Here's my .ini file. Note the path to the subroutines.
12 Jan 2022 00:07 #231501
by spumco
If you're still having issues with 4th axis jog speed (using screen buttons), see the thread here:
forum.linuxcnc.org/qtpyvcp/43904-solved-...-rotary-axis-jogging
That particular issue went away when I switched to a different branch in github Probe Basic (test_layouts), so a permanent fix is being developed.
But if you're still having the issue your branch, the above post is a decent work-around.
Replied by spumco on topic Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
I had a debian 9, linuxcnc 2.8 and probe basic setup working great except for the jogging speed issue on my 4th axis. So I thought I would upgrade to get that fixed. But, I can't get probe basic working. I'm very new at linux and git.
The following user(s) said Thank You: cmw
12 Jan 2022 04:34 #231523
by cmw
Thanks, I followed those instructions and now have rotary axis jog speed control....yay!!
Learning more everyday!
- Thank you received: 5944
12 Jan 2022 06:05 #231529
Do not hijack topics, start a new topic if it is not related to this !!!
This is for installation issues and solutions not for ini and hal or whatever other issues ...
Replied by tommylight on topic Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
16 Jan 2022 22:25 #232077
by jriotto
Replied by jriotto on topic Definitive guide to installing MX Linux, Probe Basic and LinuxCNC 2.9
from Flyer007:
Has anyone tried this with the Wildfire release? I am having some issues.
Also there are some steps in directions that seem off.
at cp ~/qtpyvcp/scripts/.xsessionrc ~/ I have to use full path for it to work
Then
mkdir ~/linuxcnc
mkdir ~/linuxcnc/configs
Error out as the directories are already there
Lastly;
git clone git://github.com/kcjengr/qtpyvcp.conversational-gcode.git
git checkout python3
you need a cd qtpyvcp.conversational-gcode before checkout
When I finish, I can start linuxcnc from terminal I don't see anything in the MX start menus for linuxcnc only QT designer
I was able to get PB sim to load once. I don't see any PB_Lathe in the linuxcnc selection list
figured out the menu item. Never did a RIP install. got it
So, I'm having the exact same situation. How do I get the LinuxCNC back into the MX Start menu? Thx!
Then
mkdir ~/linuxcnc
Lastly;
Time to create page: 0.251 seconds
