Installing QtVCP
19 Feb 2020 10:28 - 15 Oct 2021 22:06 #157829
by phillc54
Installing QtVCP was created by phillc54
There is a script available on the LinuxCNC repository to automate the installation of QtVCP requirements.
It will install the basics required to run a QtVCP GUI.
It will prompt to ask if you want to install designer to create QtVCP GUI's
You can run the script directly from a terminal as follows.
Run in place installation:
Package installation (Buildbot):
The scripts are available directly from:
Master Branch: here
2.8 Branch: here
~/linuxcnc-dev/lib/python/qtvcp/designer/install_script
/usr/lib/python3/dist-packages/qtvcp/designer/install_script
Master Branch: here
2.8 Branch: here
Last edit: 15 Oct 2021 22:06 by phillc54. Reason: updated scipts and instructions
The following user(s) said Thank You: cmorley, tommylight, Clive S, Joco, Pro_El, robertspark, persei8, thefabricator03, BeagleBrainz, daiman444 and 2 other people also said thanks.
- BeagleBrainz
- User is blocked
- Thank you received: 570
19 Feb 2020 10:47 #157833
by BeagleBrainz
Replied by BeagleBrainz on topic Installing QtVCP
Good work Old Mate
20 Feb 2020 10:49 #157975
by hottabich
Replied by hottabich on topic Installing QtVCP
How long does it take to install Qtvcp?
20 Feb 2020 11:14 #157979
by phillc54
Replied by phillc54 on topic Installing QtVCP
A couple of minutes.
- BeagleBrainz
- User is blocked
20 Feb 2020 11:20 - 20 Feb 2020 11:21 #157981
by BeagleBrainz
The biggest "how long variable" will be your download speed and how quick your machine unpacks everything. But after looking at phils script it is some good work and is quicker and less error prone than typing in commands.
Give it a try and report back, whether you have success or not. That's how you can help him out.
Last edit: 20 Feb 2020 11:21 by BeagleBrainz.
21 Feb 2020 16:31 #158147
by hottabich
Thanks for attention! Add to the instructions, run in the terminal. For people like me. Everything settled well and bistro. Thank you for your work.
21 Feb 2020 22:34 #158159
by phillc54
Can you check the first post and see if that looks OK.Thanks for attention! Add to the instructions, run in the terminal. For people like me. Everything settled well and bistro. Thank you for your work.
14 Mar 2020 12:44 #160166
by bbsr_5a
Replied by bbsr_5a on topic Installing QtVCP
on what OS will this work
there are peaple using varios combinations
i woudt like to see a warning that tels please update to 2.x First
isent there also a depencies clinch as it installs not the os related QT like 5.4 against 5.8
14 Mar 2020 22:37 #160220
by phillc54
Qtvcp is only in the docs for 2.8 and master.on what OS will this work
There is a different version of libpyqt5_py2.so for qt5.5, qt5.7 & qt5.9 and that is handled by the installer script.isent there also a depencies clinch as it installs not the os related QT like 5.4 against 5.8
The following user(s) said Thank You: BeagleBrainz
06 Apr 2020 17:12 #162935
by grijalvap
Replied by grijalvap on topic Installing QtVCP
does that scrip work on raspberry py?
can I install QtVCP on raspberry pi?
what are the diference between QtVCP and QtPyVCP?
The following user(s) said Thank You: fotros
Time to create page: 0.127 seconds
