Installing QtVCP
I seem to recall Chris mentioning this somewhere recently but I cannot seem to find it, hopefully he will chime in.I did a restart (when in doubt, pull the plug out and it seems to fire up with all of the linuxcnc bits
The following messages when starting from terminal:
rob@RobsCNC:~$ designer -qt=5
('Qtvcp python plugin found:', '/home/rob/.designer/plugins/python/qtvcp_plugin.pyc')
[QtDesigner][INFO] Logging to "/home/rob/qtdesigner.log" (logger.py:100)
tool_mmap_user(): file open fail: No such file or directory
tool_mmap_user(): no mmap file,continuing
mmap tool data not available, continuing emc/usr_intf/axis/extensions/emcmodule.cc
[QtDesigner.QT5_GRAPHICS][WARNING] linuxcnc staus failed, Assuming linuxcnc is not running so using fake status for a XYZ machine (qt5_graphics.py:214)
EDIT: I found the issue: github.com/LinuxCNC/linuxcnc/issues/1067
This printout is expected now - This is not an actual error.
This is also fixed and now available on buildbot installs.
libpyqt5_py2.so.tar.gz not found in /usr/lib/python2.7/dist-packages/qtvcp/designer/x86_64/qt5.11/
I can confirm that there is no qt5.11 folder within /usr/lib/python2.7/dist-packages/qtvcp/designer/x86_64/
Doing it manual doesn't resolve my problems either.
Axis works, but QTplasma refuses to work. Always get Qtvcp / Qtwidgets and QT-core errors. (On Mint 19.3 everything works.)
I'm new and just trying to convert my router to a plasma table with a mesa 7i96. I've got a long way to go..
I don't use use Mint so I can't help you there...Did you get this working on Mint 20.1 , I can't install the script from the repo 'linuxcnc-uspace-dev package' because of uninstallable python-serial and python-yapps dependencies. (master branch).
If you are new to LinuxCNC then it would be best to start with a known working distribution.I'm new and just trying to convert my router to a plasma table with a mesa 7i96. I've got a long way to go..
- Thank you received: 5945
I don't believe there is a buildbot version for python3
Python3 is not ready for prime time IMHO
