Installing QtVCP
19 Apr 2020 09:27 #164618
by Bruedney
Replied by Bruedney on topic Installing QtVCP
19 Apr 2020 18:36 #164661
Replied by cmorley on topic Installing QtVCP
Well that's got me stumped at the moment. It's complaining that it can't find the folder that it is in..I think I forget how links are reported.
I'll try to find an installed version of linuxcnc here and see if I can figure it out.
The following user(s) said Thank You: Bruedney
19 Apr 2020 22:38 #164680
by Bruedney
Could it be something to do with "pyqtdesignerpath"? I can't find out how to check what this is set to
Cheers
Bruce
Cheers
Bruce
19 Apr 2020 22:53 #164685
I'm not sure. The error comes from qtvcp's plugins not finding the rest of the plugins - it's like python is not searching the right path.
I don't test installed versions so I don't know the details off hand yet.
Chris
Chris
19 Apr 2020 23:09 #164689
can you remove the other libpyqt5.so file?
You need to be sudo to do this and I would trash or move it not delete it ( in case you need it back for some reason)
19 Apr 2020 23:11 #164690
the error message seems to be related to python3 which the other library.so is using
20 Apr 2020 00:51 #164702
by Bruedney
Hi Chris
Thanks for your help on this
It may have been the PYQTDESIGNERPATH. I went through another thread that I found that said to run export PYQTDESIGNERPATH='/path/to/plugin/directory/'
I took the text too literally and kept the ' marks
I just ran export PYQTDESIGNERPATH=/usr/lib/x86_64-linux-gnu/qt5/plugins
And now I get the following when I run designer (and still no widgets) (I get the same if the libpyqt5_py2.so is named this or libpyqt5_py2.bak)
qt5ct: using qt5ct plugin
qt5ct: D-Bus global menu: no
libpng warning: iCCP: known incorrect sRGB profile
qt5ct: D-Bus system tray: no
When I close QT Designer I get an extra error
QXcbConnection: XCB error: 3 (BadWindow), sequence: 709, resource id: 54538204, major code: 40 (TranslateCoords), minor code: 0
Maybe I should try uninstalling all QT related packages and then run Phil's script again
Cheers
Bruce
Cheers
Bruce
20 Apr 2020 04:57 #164742
did you try what I asked first?
20 Apr 2020 07:00 #164787
by Bruedney
Hi Chris
Yes I removed the libpyqt5_py2.so to no avail
I then tried the PYQTDESIGNERPATH again with libpyqt5_py2.so both in place and removed. libpyqt5_py2.so status did not make any difference either way
As this is on a dev machine and not my actual controller PC I think it might be time for yet another clean install.
Maybe I should go back to the offical Debian iso too
Thanks again for your help
Bruce
Bruce
20 Apr 2020 08:32 #164806
by Bruedney
Clean install of OS - Linuxcnc & QtVCP has solved my Designer issue
Big thanks to Chris for trying to help me out
Cheers
Bruce
Cheers
Bruce
Time to create page: 0.289 seconds
