Installing QtVCP
20 Apr 2020 16:53 #164873
Replied by cmorley on topic Installing QtVCP
I'm glade you got it but boy i'd like to know what the problem was
Chris
Chris
05 Jul 2020 04:40 - 05 Jul 2020 05:01 #173644
by Reinhard
Replied by Reinhard on topic Installing QtVCP
I just discovered this fred and thought: give it a try ...
... but script did not work on my installation. So I checked the source and found an error. When the script does not find a rip-installation and rip has been selected as installation format, it asks for the directory of the rip-installation.
But it asks that in an endless loop, as it is not able to use the entered path.
line 60ff is:
and should be:... as linuxcnc is installed at /usr/local/src/linuxcnc-dev
cheers Reinhard
P.S.: just discovered, that the "fixed" script does not work either. qttools5-dev has version 5.11.3-4 which is not handled by linuxcnc or the script. Changing the script so that it uses 5.9 from linuxcnc makes the script pass, but designer starts without any lc-widgets.
line 60ff is:
* ) if [ -f ~/$basedir/lib/python/qtvcp/designer/x86_64/qt$qtver/$qtfile ]; then
sofile=~/$basedir/lib/python/qtvcp/designer/x86_64/qt$qtver/$qtfile
and should be:
* ) if [ -f $basedir/lib/python/qtvcp/designer/x86_64/qt$qtver/$qtfile ]; then
sofile=$basedir/lib/python/qtvcp/designer/x86_64/qt$qtver/$qtfile
cheers Reinhard
Last edit: 05 Jul 2020 05:01 by Reinhard.
30 Sep 2020 05:01 #184349
by web123456
Replied by web123456 on topic Installing QtVCP
how to install QtVCP on
Debian Wheezy 7 Linuxcnc 2.9.
30 Sep 2020 05:31 #184351
IIRC there are no official packages for qt5 for wheezy.
It may be possible but I think you would be better off trying to build a newer distribution to upgrade.
The following user(s) said Thank You: Pro_El
02 Dec 2020 02:47 #190826
by Pro_El
Replied by Pro_El on topic Installing QtVCP
I am trying to install linuxcnc widgets but i am stuck
I am on Buster with LINUXCNC 2.9
I follow procedure from HTML docs but widget did not show
I have qttools version 5.11.3-4 maybe that is the problem??
I can see libpyqt5_py2.so show in qtDesigner Help/plugin, but still no widgets
I use file libpyqt5_py2.so that i found on this forum from cmorley who say is for Buster but still the same
What can i do to show widgets on QT-Designer?
02 Dec 2020 02:54 #190827
open a terminal
type in :
designer -qt=5
and post what it says.
Also is there any other library named similar to libpyqt5.so?
type in :
designer -qt=5
02 Dec 2020 03:03 #190828
by Pro_El
I deleted libpyqt5.so like i see in one post, now i have only libpyqt5_py2.so and other 2 with no similar names.
When i start designer -qt=5 nothing in terminal just starts QT- Designer.
What else should i do?
02 Dec 2020 03:08 #190830
Did you make add a link to the qtvcp_plugin.py to the folder that designer searches?
linuxcnc.org/docs/2.8/html/gui/qtvcp.htm...ude_linuxcnc_widgets
02 Dec 2020 03:16 #190832
by Pro_El
Thanks Cris for this help
For the link i do this
sudo ln -s /usr/lib/python2.7/dist-packages/qtvcp/plugins/qtvcp_plugin.py /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/
I am not sure if this is right way to do link??
02 Dec 2020 03:34 #190835
I always do the link with the GUI ....
No the second path should be :
/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/python
or
~/.designer/plugins/python
Did you confirm those are the correct paths? Different systems have slightly different paths.
or
Time to create page: 0.193 seconds
