Installing QtVCP
Thanks for Great support
- Thank you received: 5945
I would not know where to start, and i have developed a huge amount of disgust for QT, but it does result in some nice looking stuff, so ....
Haha, I am slowly beginning to like it.
- robertspark
- Thank you received: 216
libpyqt5_py2.so.tar.gz not found in /usr/lib/python2.7/dist-packages/qtvcp/designer/x86_64/qt5.11/
I can confirm that there is no qt5.11 folder within /usr/lib/python2.7/dist-packages/qtvcp/designer/x86_64/
(there is a qt5.5, qt5.7 and qt5.9 however)
how would one compile / find libpyqt5_py2.so.tar.gz for qt5.11?
(I am running the latest master of linuxcnc V2.9.0-pre0-3502-gc4065a899 installed via buildbot [not RIP], installed qtcvp via phil's script in the first post (+ reinstalled the following just to make sure I did not miss something)
sudo apt-get reinstall qttools5-dev-tools -y
sudo apt-get reinstall qttools5.dev -y
sudo apt-get reinstall libpython-dev -y
trying to work my way through this:
linuxcnc.org/docs/devel/html/gui/qtvcp.h..._sheet_custom_screen
thanks,
github.com/LinuxCNC/linuxcnc/tree/master...signer/x86_64/qt5.11
I noticed another issue with the script today that I am working on and should fix tomorrow but it is related to run in place installs.
- robertspark
I get the feeling I am so close.
('Qtvcp python plugin found:', '/home/rob/.designer/plugins/python/qtvcp_plugin.py')
[QtDesigner][INFO] Logging to "/home/rob/qtdesigner.log" (logger.py:100)
[QtDesigner.QTVCP.WIDGETS.MDI_HISTORY][DEBUG] MDI History file created: /home/rob/.axis_mdi_history (mdi_history.py:72)
ICE default IO error handler doing an exit(), pid = 6058, errno = 32
- robertspark
The following messages when starting from terminal:
rob@RobsCNC:~$ designer -qt=5
('Qtvcp python plugin found:', '/home/rob/.designer/plugins/python/qtvcp_plugin.pyc')
tool_mmap_user(): file open fail: No such file or directory
tool_mmap_user(): no mmap file,continuing
mmap tool data not available, continuing emc/usr_intf/axis/extensions/emcmodule.cc
[QtDesigner.QT5_GRAPHICS][WARNING] linuxcnc staus failed, Assuming linuxcnc is not running so using fake status for a XYZ machine (qt5_graphics.py:214)
