Recording coordinates
13 Jun 2011 13:49 #10466
by martig
Recording coordinates was created by martig
Hi
I have a 4 axis router setup. What I would like it to is following:
the tool should move according to the G-Codes like a router would otherwise, but upon receiving an input it should record it's current position to a log (file) and just continue moving along the path.
Reading through the manuals I didn't find an easy way to log the coordinates. Does anyone have an idea on how to achieve this?
13 Jun 2011 18:20 #10467
Replied by PCW on topic Re:Recording coordinates
I think HAL sampler is the way to record a trace file, but beyond that you need a HAL guru...
14 Jun 2011 12:11 - 14 Jun 2011 12:13 #10486
Replied by andypugh on topic Re:Recording coordinates
martig wrote:
Is the input going to happen during auto-operation? If so, then it is annoyingly difficult to do what you want.
The following will only work if the machine is _not_ in AUTO mode:
Inside G-code you can use (LOG, xxxxxx) to output to a file:
www.linuxcnc.org/docview/html/gcode_main.html#sub:Messages
In theory you could call that code on a pin going high with an MDI_COMMAND
linuxcnc.org/docs/html/gui_halui.html#sub:MDI
Depending on the version of emc2 you are using the current coordinates might be available in #5420 to #5428 (and, in the latest development they are likely to be available as #<_X> etc).
www.linuxcnc.org/docview/devel/html/gcod....html#sec:Parameters
So, you might be able to add the following in the indicated parts of the INI file
[HAL]
{existing stuff}
HALUI=halui
[HALUI]
MDI_COMMAND = (LOG, #5420, #5421, #5422)
and then in the HAL file something like:
net log-now halui.mdi-command-00 <= parport.0.pin-04-in
However, that won't work with older versions, in those you have to use a trick to get the current coordinates:
[HALUI]
MDI_COMMAND = O<lognow>CALL
Then create a file called lognow.ngc, put it in the directory pointed to by PROGRAM_PREFIX (in the INI file) and put the following in it
(Though, I am not sure which version of EMC2 introduced O-sub call from MDI_COMMAND)
It sounds like you might actually be wanting to do probing, though, and you can get G38 probing to automatically log to file.
Hi I have a 4 axis router setup. What I would like it to is following:
[HAL]
{existing stuff}
HALUI=halui
[HALUI]
[HALUI]
O<lognow> SUB
G92 X0 Y0 Z0 ;store current XYZ in G(2 offset parameters
(LOG, #5211, #5212. #5213)
G92.1 ;clear and cancel the G92 offsets
O<lognow> ENDSUB
M2
Last edit: 14 Jun 2011 12:13 by andypugh.
Time to create page: 0.073 seconds
