home z before cutting each detail
I thought to put a procedure to MXXX
Unfortunately I do not know if this is possible, because when I try machine back to the beginning of the work.
Is your plasma equipped with a floating torch with a probe input?
I'm looking for how to do homez during program execution, befor cutting each detail in my plasma
You want to home to the limit switch? I am not sure how to do that, though it might be possible using a custom M-code something like
#! /bin/bash
halcmd setp halui.joint.2.home
What are you trying to achieve? It might be that there is a better way to get the same effect.
To be honest, if you need to re-home more than once a day, something is wrong.
You only need to home an axis once.
thin sheet metal bends when cutting, so I would like to reset the axle before any detail
I want to connect the SW home switch so that it worked when the torch touches the material
I tested it, and when the program hit the M100 he comes back to the beginning of work.You want to home to the limit switch? I am not sure how to do that, though it might be possible using a custom M-code something like
#! /bin/bash
I can do the movie what happens on another machine where it is tested
![:laugh: :laugh:](/media/kunena/emoticons/laughing.png)
I think what you need to do is probe, not home.thin sheet metal bends when cutting, so I would like to reset the axle before any detail
You could then use G10 to set the Z height on the basis of the probe result.
Better still would be an automatic torch height control, lots of people have that, including JT.
Connect a switch to motion probe input and use a probe motion as Andy suggested.
I apologize for such a question, but I still do not understand it exactly.
however, a call home by M100 imparted to me in another machine ...
![:) :)](/media/kunena/emoticons/smile.png)
www.linuxcnc.org/docview/html/gcode_main...ub:G92,-G92.1,-G92.2,
After the cutting is done I turn off the offset with G92.1
I have one more question. Is it possible to use the same switch as a probe and home?
