Re:Backlash Compensation
02 Mar 2022 04:42 #236164 by Matt Hat
Replied by Matt Hat on topic Re:Backlash Compensation
Is there a description of the HAL pins: joint.X.backlash-corr, joint.X.backlash-filt? The joint.X.backlash-vel is clear I guess.
02 Mar 2022 17:36 #236226 by andypugh
Replied by andypugh on topic Re:Backlash Compensation
You seem to have found a 12 year old thread to reply to. Not that it matters, particularly.
Those pins are all outputs, quite possibly supplied only for debugging purposes.
What that means is that they are probably not very useful to you, they tell you what the system is doing in response to your other settings.
They are very briefly described in the motion manpage:
linuxcnc.org/docs/2.8/html/man/man9/motion.9.html
Time to create page: 0.250 seconds
