Limit3 question.
Both methods are very interesting for me!...
You can use setp. One way might be.
Write a handler for the slider or spinbox you set the new max accel with.
From that handler fork halcmd setp stepgen.0.maxaccel [value]
See the Forum discussion under Glade > Label regards writing python event handlers for glade widgets
Another way would be to write a user M code script which does the same thing and call it from your g code at the point
where you want to limit accel to a given value, no pretty gui sliders but can be written in 2 minutes.
yesterday i was trying to setup handlers, but the only way i know howis to create an hal_out_pin inside the python script. But then as you know i can't net that pin with a param.
can you explain what you mean for 'fork'?
how can i write that into python?
In the future it will be very usefull for me to use a personalized M-code, but for now it should be enough to know that i can change it.
Thanks, Davide.
Put the below into a file named M111 in the directory pointed to in your .ini file by [DISPLAY] PROGRAM_PREFIX =In the future it will be very usefull for me to use a personalized M-code, but for now it should be enough to know that i can change it.
and make it executable (chmod 755)
Then you can use M111 Pn Qnnn in the MDI or in your code, where P is the stepgen number and Q is the integer value to set the stepgen maxaccel to.
#!/bin/bash
if [ ! $# -ge 2 ]; then
echo "Usage: M111 Pn Qn - where arg1 is stepgen number & arg2 is maxaccel value "
exit 1
fi
float=$1
float2=$2
stepgen=${float/\.*}
maxaccel=${float2/\.*}
halcmd setp stepgen.$stepgen.maxaccel $maxaccel
exit 0
fork and spawn and all their variants are the ways that you start a child process through a shell in C.
I don't know anything about python, but there must be similar ways to do this in that language.
You'll need to do some reading, it can get complicated if you need to capture output or set up notification handlers to check the exit code etc, but at its simplest you just launch the process into the wild blue yonder and hope it all goes OK!
One for a rainy day perhaps?
Is it so simple?!?Hi
#!/bin/bash if [ ! $# -ge 2 ]; then echo "Usage: M111 Pn Qn - where arg1 is stepgen number & arg2 is maxaccel value " exit 1 fi float=$1 float2=$2 stepgen=${float/.*} maxaccel=${float2/.*} halcmd setp stepgen.$stepgen.maxaccel $maxaccel exit 0
i'm going to study some to understand what '[ ! $# -ge 2 ]' stands for... i wish to find some docs on this..
during these days i'm studying a lot of python 'cause i'm working for Opera theater and it gives a looot of free time!
but i don't understand what you suggest to do. Can you just explain the logic of the process?
do you mean to call the param setting from the python script directly? ..sorry it's my poor english fault..
now thank you very much for the m-code hint.
in the thruth i'm using JA3 branch, and inside this branch i shouldn't change stepgen.N.acceleration, but the Traj Planner acceleration (at least i think..), but i don't know which is the pin.
Is it so simple?!?
You need to look up bash programming in google
Means 'if commandline args not greater or equal to 2' basically (checks both P and Q args used)
It is a big and often complex process, you need to look up on google
For instance
www.yolinux.com/TUTORIALS/ForkExecProcesses.html
Basically system, spawn, spawnl, fork, exec, execv and all the other similar functions, start a child process, doing something different to or complementary to the the main program.
The differences are in whether the process is independent of the spawning program and continues after it closes, whether it is in an OS dependent shell or a new thread, if you capture and use its output, whether you handle its exit and use the code to determine future actions, etc etc etc.
Python will have a function which just executes a command through the OS's default shell (bash or sh), its just a question of finding it and figuring out the best way to use it.
Then your python program can get the value from your pyvcp slider or whatever and set the parameter directly with a system call.
Not something I can explain much more, you need to do a lot of reading until it becomes clear to you.
Thanks, i got this.
Is it so simple?!?
Good explanation. Now i understood what's the logic. It seems feasible..after some studying..
For instance
ArcEye, thank you very much for your suggestions and explanations.
it's much appreciated. I'm going to work on it.
Ciao, Davide.
-run Emc2 RIP
-open Hal config windows to see results..
-open a terminal and type:
I can see the hal_param changing inside the window, so do you think it can be enough?dab@dab-tetra:~$ python
Python 2.6.5 (r265:79063, Apr 16 2010, 13:09:56)
[GCC 4.4.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import os
>>> x = 2400
>>> os.system("halcmd setp stepgen.0.maxaccel %d"%x)
0
>>> x = 2500
0
dab@dab-tetra:~$
If it does the job, it is enough. You just have to figure out your GUI interface and write the code to update theI can see the hal_param changing inside the window, so do you think it can be enough?
maxaccel values.
As I pointed to previously, look at this thread
www.linuxcnc.org/index.php/english/compo...=48&id=16439&limit=6
for ideas on how to write a glade gui and then have a python event handler execute some code when the state of a pin changes.
good luck
I had only on setting param from python.
Thanks again.
