Setting up a tool changer
09 Apr 2012 21:09 - 09 Apr 2012 21:11 #19060
by fferraz
Replied by fferraz on topic Re:Setting up a tool changer
Also, is it right to think my new logic (with the counter) would be this:
if tool change is true turn on parallel pin 16
if tool change is true preset counter 1 with tool-prep-number
if tool change is true start timer 1 (preset 50ms)
if timer 1 is on turn on parallel pin 17
if timer 1 is done
and counter is done
and parallel pin 10 is on return tool change done
if timer 1 is done and counter is not done reset timer 1
Last edit: 09 Apr 2012 21:11 by fferraz.
09 Apr 2012 23:31 #19072
by BigJohnT
Replied by BigJohnT on topic Re:Setting up a tool changer
You will have to write the value into the preset with an assignment block.
linuxcnc.org/docview/html/ladder/classic..._variable_assignment
linuxcnc.org/docview/html/ladder/classic_ladder.html#_counters
10 Apr 2012 13:35 - 10 Apr 2012 13:36 #19092
by fferraz
Nice... BigJohn, I've completed my first attempt at making this work, but, of course, it's still not working! ![:P :P](/media/kunena/emoticons/tongue.png)
What I'd like you to do, if it's not asking much, is take a look at my .clp file to see if my logic is correct, or what I need to change. Remember that I'm a total virgin when speaking of ladder so I may have committed some ridiculous mistakes hehehe.
I'm attaching the file here . Also I think you should know my custom.hal file now has this:
Tell me if you need any more info.
Thanks again!
net tool-cng-req iocontrol.0.tool-change => classicladder.0.in-01
net tool-prep-number iocontrol.0.tool-prep-number => classicladder.0.s32in-01
net tool-cn-done iocontrol.0.tool-changed <= classicladder.0.out-01
net enable-tool-change classicladder.0.out-02 => parport.0.pin-16-out
net pulse-bit classicladder.0.out-03 => parport.0.pin-17-out
net tool-changed-bit classicladder.0.in-02 <= parport.0.pin-10-in
Thanks again!
Last edit: 10 Apr 2012 13:36 by fferraz.
10 Apr 2012 13:57 #19094
by BigJohnT
I don't see anything that jumps out at me except when I try and run it I see tool prepare bit come on but I don't see tool change come on. If I get a chance today I'll open my ladder up and see. Also if you go to the Symbol names and click on the middle column and you can put a short name in there so it shows up instead of the %I1 stuff. Also open up the ladder editor and set a watch window in show hal config for the pins to see what they do when you try and do a tool change. Of course I can't run your config without the inputs...
10 Apr 2012 15:01 #19098
by BigJohnT
Because I have no need for tool prep I just pass it through with this line. Otherwise it just waits for tool prepared to go true.
net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
29 May 2012 16:33 #20484
by fferraz
FINALLY DONE!! ![B) B)](/media/kunena/emoticons/cool.png)
I'd like to thanks andypugh and BigJohnT for the HUUUGE help on this topic.
After so much time, the ladder and HAL logic are finally all perfect for what I need. I'm now just finishing the last tweeks on my machine so that I can finally start using it at full power, but I can now say that LinuxCNC is doing everything I need.
I'll attach my clp file to be available to anyone who may need them, to actual use or just as examples.
Also my custom.hal file is the following now:
p.s.: One last question: every time I have to change something in stepconf, it creates 2 lines in my hal file:And since I'm using those signals in my custom.hal, I have to always go and comment those lines. Is there anyway that those lines are not created?
Thanks again!!
FELIPE
net tool-change iocontrol.0.tool-change => classicladder.0.in-01
net tool-number iocontrol.0.tool-prep-number => classicladder.0.s32in-01
net enable-tool-change classicladder.0.out-01 => parport.0.pin-16-out
net pulse-bit classicladder.0.out-02 => parport.0.pin-17-out
net tool-changed-bit classicladder.0.in-02 <= parport.0.pin-15-in
net tool-cn-done classicladder.0.out-03 => iocontrol.0.tool-changed
net tool-number <= iocontrol.0.tool-prep-number
net tool-change-loopback iocontrol.0.tool-change => iocontrol.0.tool-changed
Thanks again!!
FELIPE
29 May 2012 19:32 #20492
by BigJohnT
fferraz wrote:
Yes, quit using stepconf as you have progressed past that by now if your hand editing your configuration files. Stepconf is only meant to give new users a jump start.
And since I'm using those signals in my custom.hal, I have to always go and comment those lines. Is there anyway that those lines are not created?net tool-number <= iocontrol.0.tool-prep-number net tool-change-loopback iocontrol.0.tool-change => iocontrol.0.tool-changed
Thanks again!!
FELIPE
29 May 2012 19:39 #20493
Replied by andypugh on topic Re:Setting up a tool changer
fferraz wrote:
[quotep.s.: One last question: every time I have to change something in stepconf, it creates 2 lines in my hal file:And since I'm using those signals in my custom.hal, I have to always go and comment those lines. Is there anyway that those lines are not created?
[/quote]Whilst I largely agree with John that you should now stop using Stepconf, if you putat the beginning of your custom.hal then you can redefine and reconnect everything.
delsig rool-number
delsig tool-change-loopback
Time to create page: 0.157 seconds
