Quadrature output (ULN2803 type) - how to?
01 Mar 2010 07:44 - 01 Mar 2010 07:46 #2132 by melsoft
Replied by melsoft on topic Re:Quadrature output (ULN2803 type) - how to?
Here are the files I modified folowing PCWs advices:
File Name: config.zip
File Size:4 KB
You probably need to edit SCALEs and VELOCITIes (see stepper_mm.ini) according to Your steppers. Also the homeswitsches are not configured yet (are in default state) because I don t need them yet.
I added the FILTER section to stepper_mm.ini (filters for importing pictures). You probably don t need, it is useful for importing pictures to G-Code.
Enjoy!
melsoft
Last edit: 01 Mar 2010 07:46 by melsoft. Reason: not allowed to include .ini, .hal files
01 Mar 2010 07:49 #2133 by cjgaus
Thanks for the reply melsoft ill check it out and try give it a go in emc. I havent used it yet so will be interesting running the plotter off linux
01 Mar 2010 08:25 #2134 by cjgaus
hmm i seem to be having a error with the code
06 Jan 2014 01:34 #42372 by Do0tmaster5
Replied by Do0tmaster5 on topic Quadrature output (ULN2803 type) - how to?
hi, where i had to place the files in emc? i cand find anny direction with this files... im a typical windows user^^ pls can annybody help me??
06 Jan 2014 02:57 #42373 by PCW
If you mean "where do the configuration files go"
They normally go in
home/linuxcnc/configs/
so if you open terminal (control alt t on ubuntu)
and type
cd linuxcnc/configs
you will be in the main configuration directory
if you type
ls
you should get a list of various subdirectories that contain hal
and ini files for different types of interface hardware and machines
The following user(s) said Thank You: Do0tmaster5
06 Jan 2014 07:24 #42379 by Do0tmaster5
Jepp, that was what im searching for^^ BIG THX !!!! ;)
Time to create page: 0.385 seconds
