Configuring LinuxCNC
Advanced Configuration
5 axis kinematic
5 axis kinematic
Thank you received: 4801
02 Jun 2012 10:54 #20589
maufissi wrote:
To my understanding, with the correct kinematics, I should be able to run the machine with the RTCP (rotation tool center point). This way the cam only needs to send to emc XYZ coordinate and tool tip orientation in the B and C axes with respect to the machined surface.
Yes, that is exactly the point of LinuxCNC Kinematics.
A good example if this is that an industrial robot can run the LinuxCNC splash-screen code unmodified because the kinematics converts XYZ tool-tip positions into joint angles.
5 axis kinematic
Time to create page: 0.295 seconds
