Acceleration of U-Axis asynchronous to XYZ
- poolspieler
25 Jun 2012 19:13 #21316
by poolspieler
Replied by poolspieler on topic Re:Acceleration of U-Axis asynchronous to XYZ
Ok,
I found this linuxcnc.org/docs/html/man/man9/hypot.9.html#FUNCTIONS page.
This should explain, how to use it.
Now I have to understand, how to build an own comp.
Best Regards,
Andy
Best Regards,
Andy
25 Jun 2012 19:25 #21318
Replied by andypugh on topic Re:Acceleration of U-Axis asynchronous to XYZ
poolspieler wrote:
It would be handy, wouldn't it? Those pages are just auto-generated from the components themselves.
You could read this doc: www.linuxcnc.org/docs/html/hal/intro.html
But it boils down to adding this to your HAL (put it in the custom.hal if you don't want stepconf to over-write it)
loadrt hypot count=1
addf hypot.0 servo-thread
net xvel axis.0.joint-vel-cmd hypot.0.in0
net yvel axis.1.joint-vel-cmd hypot.0.in1
And then the cartesian velocity can be seen on the hypot.0.out pin.
You can compare it to motion.current-vel pin. If it is the same then there is no point having it. Whether it is the same depends on if U is part of the built-in velocity command.
I am wondering if there is any scope for using adaptive feed based on a goop-pressure sensor.
25 Jun 2012 19:42 #21320
Or it that's too hard sensor wise, model the extruder and use that for the adaptive feed rate control
Replied by PCW on topic Re:Acceleration of U-Axis asynchronous to XYZ
- poolspieler
25 Jun 2012 20:18 #21321
by poolspieler
25 Jun 2012 20:25 #21323
by BigJohnT
Replied by BigJohnT on topic Re:Acceleration of U-Axis asynchronous to XYZ
Time to create page: 0.265 seconds
