Max machine velocity with different axis maxes
24 Jul 2012 13:05 #22394
by clkeck1
Max machine velocity with different axis maxes was created by clkeck1
I posted this in the basic configurations but haven't got to the root so I'm trying here.
I'm trying to get the Max velocity override hooked up on the lathe. I have a 2%, 25%, 50%, and 100% inputs from a rotary switch. A mux16 setup using pncconf outputs 2, 25, 50, or 100 max-velocity-counts pin. The issue is the X axis Max velocity is 236 and the z is 472.
I verified the mux output in Hal configuration and it outputs the corresponding 2, 25, 50, & 100
With them different the slider starts at 472 but once you change the switch it stays at 236 at 50% and 100%. but you can slide it back to 472 in axis
If I set both axis to 472max in the ini file everything works correctly.
Has anyone else ran into this or have a fix for it?
Ini file below
Hal section below
Cory
Ini file below
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/sl-4/linuxcnc/nc_files
PYVCP = pyvcp-panel.xml
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
LATHE = 1
DEFAULT_LINEAR_VELOCITY = 0.833333
MAX_LINEAR_VELOCITY = 7.916667
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xz
[TRAJ]
AXES = 3
COORDINATES = X Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.79
MAX_LINEAR_VELOCITY = 7.87
POSITION_FILE = position.txt
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
TOOLCHANGE_WITH_SPINDLE_ON = 1
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 1
MIN_FERROR = 1
MAX_VELOCITY = 3.93333333333
MAX_ACCELERATION = 10.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = .00003
MAX_OUTPUT = 10.0
ENCODER_SCALE = -67733.3312
OUTPUT_SCALE = -10.0
MIN_LIMIT = -3
MAX_LIMIT = 9
HOME_OFFSET = 6
HOME_SEARCH_VEL = 1
HOME_LATCH_VEL = -0.1
HOME_FINAL_VEL = 5
HOME = 6
HOME_USE_INDEX = YES
#HOME_SEQUENCE = 1
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 1
MIN_FERROR = 1
MAX_VELOCITY = 7.86666666667
P = 50
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = .00008
MAX_OUTPUT = 10.0
ENCODER_SCALE = 25400
OUTPUT_SCALE = 10.0
MIN_LIMIT = -10
MAX_LIMIT = 30
HOME = 0
HOME_OFFSET = 0
HOME_SEARCH_VEL = -.1
HOME_LATCH_VEL = 1
HOME_FINAL_VEL = 5
#HOME_SEQUENCE = 0
Hal section below
setp halui.max-velocity.count-enable true
setp halui.max-velocity.direct-value true
setp halui.max-velocity.scale 0.078667
net max-vel-override-incr => halui.max-velocity.counts
net mvo-incr-a => mvoincr.sel0
net mvo-incr-b => mvoincr.sel1
net mvo-incr-c => mvoincr.sel2
net mvo-incr-d => mvoincr.sel3
net max-vel-override-incr <= mvoincr.out-s
setp mvoincr.debounce-time 0
setp mvoincr.use-graycode False
setp mvoincr.suppress-no-input False
setp mvoincr.in00 100.000000
setp mvoincr.in01 50.000000
setp mvoincr.in02 25.000000
setp mvoincr.in03 2.000000
Cory
Time to create page: 0.060 seconds
