Mesa card which one should I use?
- garymcrobertpdx
to a higher performance system. Which Mesa card is the one for me
,how do I decide, which one is the most popular?
The time has come to upgrade from the basic parport configuration
5i25 is likely to be a direct pin-for-pin replacement. But then a pin-for-pin replacement doesn't buy you much advantage unless you are hitting a step-rate barrier.
So, the question back to you is what you want to get from the upgrade?
- garymcrobertpdx
Speed is a problem I am limited to about a 20Khz step rate cant move my
axis fast.
At the moment I am using three parports which provides enough IO pins .
Sounds like a 5i25/7i76 combination might suit you then.
Though the 7i43 hooked on to one of your existing parports probably shouldn't be overlooked.
- garymcrobertpdx
Where can I find information on how to install and use the Mesa boards?
Have you seen: www.linuxcnc.org/docs/html/drivers/hostmot2.html
Also: www.linuxcnc.org/docs/html/man/man9/hostmot2.9.html
- garymcrobertpdx
I have some info here .
