Mesa 7i77 and linear encoder tuning PID.
www.f1-2000.co.uk/index.php?f=hardinge_hxl2
You’ll understand my woe with regard to changing motors!
Absolutely! (and very nice work too)
I guess as a last resort I could pop up with some 8i20 drives to try.
But it really ought to be possible to minimise the Omrons into controllability.
You might end up with two PID loops in HAL, one running the drive/motor under encoder feedback, and a second one (probably slow and I-only) tweaking that one from the linear scale feedback.
But I would certainly support the suggestion I think I saw earlier of running both LinuxCNC and the drives from the same encoder initially.
Every corner you turn seems to be 10 times more difficult than you possibly imagined.
This should now be the enjoyable bit, now most of the mechanical hard work is done, getting the machine setup and the making all the nice tactile bits for the control etc.
Do you and your 8i20 s fancy a little holiday in Norfolk then?
![:) :)](/media/kunena/emoticons/smile.png)
It’s been worrying me that if I change the drives, what to ... how much.... will that cure the problem....
I haven’t had a chance to get the motor encoder cable made up yet, that’s on the cards for tonight.
So I’ll report back findings from there.
As I said before, this is all virgin territory for me, so please bear with me as I’m still pretty clueless.
That said, for me, my gut instinct from the first time i starting doing battle, was the drives may be the problem.
“You might end up with two PID loops in HAL, one running the drive/motor under encoder feedback, and a second one (probably slow and I-only) tweaking that one from the linear scale feedback.”
Is that available as a “cut and paste”
![;) ;)](/media/kunena/emoticons/wink.png)
This may be a stupid suggestion, but what would happen if:
setp hm2_5i25.0.encoder.00.scale 25600... (25600 linear encoder)
setp hm2_5i25.0.encoder.05.scale 8192 ... (8192 output from drive)
then
net x-pos-fb <= hm2_5i25.0.encoder.00.position
net x-vel-fb <= hm2_5i25.0.encoder.05.velocity
or something along those lines ?
I composing an email to Omron, to see if they can shed any light ......
Probably not, though it shouldn't be any more difficult than a single PID really.Is that available as a “cut and paste”
That sort of thing ought to work fine, though I don't think LinuxCNC would do anything useful with that x-vel-fb so isn't the answer you are looking for.This may be a stupid suggestion, but what would happen if:
then
if .... you know what your'e doing!
