error after installing .comp
23 Aug 2012 18:32 - 23 Aug 2012 20:17 #23586
by dzarek
error after installing .comp was created by dzarek
I tried to run the THC according to the instructions of John.
Unfortunately, after installing a different version of thcud.comp which also changed the name of the thc.comp and so I've installed two components, I get:
help...
edit:
ok, it`s work
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 File exists
15249
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
ERROR: Module thcud does not exist in /proc/modules
<commandline>:0: exit value: 1
<commandline>:0: rmmod failed, returned -1
<commandline>:0: unloadrt failed
ERROR: Module hal_lib is in use by thc
ERROR: Module rtapi is in use by thc,hal_lib
ERROR: Module rtai_math is in use by rtapi
ERROR: Module rtai_sem is in use by rtapi
ERROR: Module rtai_fifos is in use by rtapi
ERROR: Module rtai_sched is in use by rtapi,rtai_sem,rtai_fifos
ERROR: Module rtai_hal is in use by rtapi,rtai_sem,rtai_fifos,rtai_sched
help...
edit:
ok, it`s work
Last edit: 23 Aug 2012 20:17 by dzarek.
Time to create page: 0.161 seconds
