Creating a "one button touch off" button
- Thank you received: 2162
19 Sep 2012 04:01 #24404
Replied by cmorley on topic Re:Creating a "one button touch off" button
in linuxcnc 2.5+ using P0 will set the current system regardless of what it is.
As in G10 L20 P0 X0 Y0 Z0
This was specifically added for 'touch off button' use.
Chris M
Chris M
19 Sep 2012 04:25 #24405
andypugh wrote:
L2 and L20 where never explained clear enough for me but this was my interpretation:
(This much I know is true)
L20 sets the offsets so the current location (of the tool) will display as the numbers entered.
eg L20 P0 X5 Y0 sets the current location to X 5 , Y 0 and Z will stay at what ever it was.
(This much not so sure)
L2 sets the offsets so the origin is offset by the amount requested.
eg L2 P0 X1 will offset the x axis positively by 1 (lowering the readout)
to recap if you were at X absolute zero and the user coordinate system read zero for X, then issued
G20 L20 P0 X5 the readout would say X5
same thing except:
G20 L2 P0 X5 the readout would say -5
hopefully no lies there....
Chris M
btvpimill wrote:
Thanks Andy, Can I also say x0y0z0, as I want to set a "current location is origin". I must have mis-read the doc's and am thinking setting them to zero will clear the current g5x data?
G10 L20 P1 X0 Y0 Z0 will set the current location to the origin.
G10 L2 P1 X0 Y0 Z0 will set the G54 Offsets to 0. The difference is in the L2 or L20.
www.linuxcnc.org/docs/html/gcode/gcode.h...em_a_id_sec_g10_l2_a
same thing except:
Chris M
- btvpimill
- Thank you received: 3
19 Sep 2012 11:46 #24414
by btvpimill
Replied by btvpimill on topic Re:Creating a
I will try to get some play time with this today, just to get confirmation on exacty what each does.
Thanks Andy,John, and Chris for the helpful insight to this, I will report my findings so hopefully there will be no more question - even if I am the only one who has them
- eszyman
23 Sep 2012 17:56 #24564
by eszyman
Replied by eszyman on topic Re:Creating a "one button touch off" button
Ok so we found that after running the G10L20 command the gcode display does not update and we have issues with travel since the code is not reloaded as when the axis touch off button is used,
The solution has been to write an o call to access the following codes
o<zerog54>call
M155:
Note the G10 and M155 must be on separate lines or there will be issues with the numbers not touching off unless you bounce in and out of G54
The next problem is that now we get the following axis error:
can't do that (EMC_TASK_PLAN_OPEN) in manual mode
The end result is that the file reloads and the g54 is touched off appropriately, but we'd like to rid ourselves of the error if possible. Has anyone else seen anything this?
o<zerog54>call
o<zerog54> sub
G10 L20 P1 x0y0z0a0
(debug, reloading gcode...)
M155
o<zerog54> endsub
M155:
#!/bin/sh
axis-remote --reload
- h_munktell
14 Jan 2013 03:23 #28660
by h_munktell
Replied by h_munktell on topic Re:Creating a "one button touch off" button
Great info on the axis-remote --reload! Works, but I have a problem and that is that it takes approx 5 seconds before the axis-remote command in my M155 file is executed and returning.
M155:
If I run this script in a terminal, it executes directly and I get the messege and it reloads the file in axis correctly. But if I call the M155 file from MDI, it takes 5 secons before anyting happens and I dont get the message in the terminal i started linuxcnc from. If I comment the axis-remote line away, and executes M155 from MDI, it executes directly and I get the message in the terminal. Are I'm doing something wrong or is it a bug? (I run latest master version)
--Henrik
M155:
#!/bin/sh
echo Hello
exit 0
--Henrik
- the_muck
04 Sep 2013 03:07 #38454
by the_muck
Replied by the_muck on topic Re:Creating a "one button touch off" button
Same here... any idea?
- HolgerT
23 Mar 2014 23:03 #45151
by HolgerT
Replied by HolgerT on topic Re:Creating a "one button touch off" button
