2 Spindle Router
- Topic Author
- Thank you received: 1370
23 Sep 2012 02:45 #24557
2 Spindle Router was created by Todd Zuercher
I am working on a router with two spindles each on their own vertical axis (z and w). Mostly the machine is used for carving two of something. But I would like to be able to turn on either one or both spindles. I was thinking that I could use some way to connect and disconnect each spindle to the M3 command. I don't need speed control, just on, off, and some kind of running at speed or fault fault to shut it down if something goes wrong.
23 Sep 2012 12:25 #24560
by BigJohnT
Replied by BigJohnT on topic Re:2 Spindle Router
You could use M1xx to control a relay for each spindle.
linuxcnc.org/docs/html/gcode/m-code.html...d_sec_m100_to_m199_a
