Encoder Problems
27 Sep 2012 17:35 #24668 by Todd Zuercher
I was working on tuning the servos on a retrofit I am working on, and one of the servo encoders is acting flaky. It seems to work OK at lower speeds, but when spun faster it starts to drop counts at more than a few hundred RPM. I double checked all of my connections and switched motor positions (problem followed the bad encoder). What is the possibility of being able to dissasemble the encoder cleaning it up, put it back to gether and getting it to work or is that not likely to work? The unit in question is an old Renco part. To take it appart I would have to desoder the leds in order to open it up.
27 Sep 2012 17:38 #24669 by andypugh
Replied by andypugh on topic Re:Encoder Problems
Is it old enough that there is a possibility it uses filament bulbs?
It doesn't sound like you have a lot to lose by the attempt.
27 Sep 2012 18:33 #24670 by Todd Zuercher
Replied by Todd Zuercher on topic Re:Encoder Problems
I don't think they are more than 10 yrs old.
27 Sep 2012 18:48 #24671 by PCW
Replied by PCW on topic Re:Encoder Problems
Does it have any adjustments? Sometimes older encoders have gain adjustments (potentiometers)
that affect the quadrature accuracy (90 degree phasing).
Sometimes encoders go bad from dirt buildup. A Qtip dipped in 99% Isopropyl alcohol can be used to clean the wheel, but cleaning the LED and resolver plate will require disassembly.
27 Sep 2012 19:01 #24672 by Todd Zuercher
I can't even get to the wheel without disassembly on this one.
29 Sep 2012 02:55 #24705 by Todd Zuercher
I was able to fix it. desoldered the LEDs, removed the wheel and cleaned it and the pickups with a cotton swab and denatured alcohol. The whole inside of the thing was covered with a thin sticky residue. Put it back together and with a small amount of fiddling was able to get the commutation working.
Time to create page: 0.387 seconds
