Remapping Issue 2.5.1 Toolchanger M6 Command
29 Sep 2012 15:27 #24717
by tkamsker
Remapping Issue 2.5.1 Toolchanger M6 Command was created by tkamsker
du to reading in all avail documentation i was verry successful
I now have an HEIZ400T Router miller and the toolchanger working. Everything fine.
Now for the finetuning i would like change the actual
Tx M6
o<www> call
to Tx M6 only
I used the remapping in the ini section as described in several posts here.
But it simply does nothing ,..
question 1 ) Is there a know "feature" in 2.5.1 ??
2.) How do i debug that or better where do i find an hint about where to debug ?
3.) Any extra hints ? or upcoming software versions ,..
and i try to avoid the ladder stuff my config shpuld be easily to be switched to non toolcahnger ( if i have to mill fat alu i go by and kress1050 spindle straight forward ,..
Any info is aprechiated
thx
thomas
Tx M6
o<www> call
to Tx M6 only
thx
thomas
29 Sep 2012 16:30 #24718
by ArcEye
Replied by ArcEye on topic Re:Remapping Issue 2.5.1 Toolchanger M6 Command
Hi
I think M code re-mapping is available in the master (2.6).
There is nothing in the change logs to suggest it has been added to 2.5.1
This thread seems to get to a successful conclusion
www.linuxcnc.org/index.php/english/compo...ew&catid=10&id=22863
Time to create page: 0.144 seconds
