Winch style cnc scaling???
14 Oct 2012 13:59 - 14 Oct 2012 14:07 #25303
by mt92
Winch style cnc scaling??? was created by mt92
I have my cutting machine all done and made a few test cuts and noticed that the Y and B axis moves faster than X and A. I test cut a square and it is very close in Y,B(up and down) but way too small in X,A. I have looked thru my ini file and it looks correct.
It almost seems like a kinematics error but I looked at the measurements?
Any Ideas?
Mike
Any Ideas?
Mike
Last edit: 14 Oct 2012 14:07 by mt92. Reason: added picture
14 Oct 2012 20:15 #25315
by mt92
Replied by mt92 on topic Re:Winch style cnc scaling???
15 Oct 2012 12:30 #25335
Replied by andypugh on topic Re:Winch style cnc scaling???
mt92 wrote:
Is your home position set correctly? 4 of the measurements are from the winches to the home position. You need to home the machine to that position (so that the coordinates are zero) or the kinematics calculations will all be wrong. I rather assume that you have no home switches, so this would involve jogging the machine to marks on the table then pressing the "Home" button in the interface.It almost seems like a kinematics error but I looked at the measurements?
Time to create page: 0.093 seconds
