2 motor exactly together
- revolter
- Visitor
11 Apr 2010 12:27 #2577
by revolter
2 motor exactly together was created by revolter
X axis of my CNC mill have 2 stepper motor(2.0 V 4.5A 1.8D 8wire)
how can i control this 2 motor exactly together for one axis?
can i use one Driver or i should use 2 driver with one direction and pulse pin?
11 Apr 2010 17:36 #2579
by Rick G
Replied by Rick G on topic Re:2 motor exactly together
I would normally use 2 drivers with one set of pins.
Rick G
Rick G
04 May 2010 11:51 #2799
Replied by andypugh on topic Re:2 motor exactly together
Normally you would use two separate drivers. As a more advanced topic you might want to home the motors individually to auto-square the gantry.
There is a kinematics module that maps multiple "joints" to a single "axis". Have a look in the sample configurations for the one that mentions "gantry" and "stepper" and look how that is configured.
13 Sep 2010 12:32 - 13 Sep 2010 12:56 #4169
by radekB
Replied by radekB on topic Re:2 motor exactly together
Gantry kinematics module does not work me in manual mode. with you, yes?
Can you post your HAL file?
thanks
RADEK
thanks
RADEK
Last edit: 13 Sep 2010 12:56 by radekB.
Time to create page: 0.137 seconds
