Remap M6 with "toolchange with length-probe"
- h_munktell
29 Oct 2012 00:31 #25954
by h_munktell
Remap M6 with "toolchange with length-probe" was created by h_munktell
Hello,
I'm quite new to this, but I'm trying to setup my machine with the "toolchange with length-probe" from sim/remap. Run into a few problems. Linuxcnc is on 2.6.0-pre0-3255-gce55978. Fixed a physical probe and it works. Made a simple program:
Workflow is:
1. Home machine
2. Touchoff all axes to workpiece in G54
3. Start program.
Problem with the original manual_change.ngc is that the M73 when exiting the sub reverts the tool length offset (G43) to the state before the sub was executed, effectivly canceling out the tool length offset calculated in the sub for anything other than the reference tool.
Fixed this by changing to M70 in the beginning of the sub, and M72 in the end of the sub. But after M72, I added the g43.1 z[#5063-#1000] . This works good with the above program.
Problem now is that after the first run of the program, I want to change tool, touchoff on workpiece and run it a second time. This time there is problem with the offsets, Z0 after the sub is not on workpiece. I suspect it's because after the first run of the program G43.1 is still in use, and I touch off with this, then sub changes g43.1 and messes up my Z0 somehow. If I MDI a G43 before touching off Z inbetween programs, everything is working. But I do not want to do this G43 manually before touch off every time, sometime I will forget it, be sure about it....
Any ideas on how to solve this I would appreciate.
Best regards
Henrik
( Made using CamBam - http://www.cambam.co.uk )
( Untitled 10/20/2012 9:09:54 PM )
( T1 : 3.175 )
( T2 : 3.175 )
G21 G90 G64 G40
G0 Z3.0
( T1 : 3.175 )
T1 M6
( Profile1 )
G17
M3 S1000
G0 X35.5875 Y19.0
G1 F300.0 Z0.0
G3 F600.0 X10.7063 Y33.3652 I-16.5875 J0.0
G3 Y4.6348 I8.2938 J-14.3652
G3 X35.5875 Y19.0 I8.2938 J14.3652
( Profile2 )
G0 Z3.0
( T2 : 3.175 )
T2 M6
g43.1 z[#5063-#1000] (set new tool offset)
M3 S1000
G0 X35.5875 Y19.0
G1 F300.0 Z0.0
G0 Z3.0
M5
M30
Workflow is:
1. Home machine
3. Start program.
Best regards
Henrik
29 Oct 2012 01:48 #25962
by BigJohnT
Replied by BigJohnT on topic Remap M6 with "toolchange with length-probe"
Do you have to load a tool then touch off the Z?
Just a SWAG but it seems you need to set the tool table with G10 L11 in a sub to touch off on the fly in a subroutine... IIRC I do something like this on my lathe to set a new tool on the turret.
29 Oct 2012 06:58 #25971
If you want the tool length to be persistent then you need to store the length to the tool table using G10 (which has a number of options which I can't recall, but are documented)
Replied by andypugh on topic Remap M6 with "toolchange with length-probe"
I think that the original application of that demo was for a machine with no repeatable tool-length, and the idea is that the machine re-probes on every tool change.Problem with the original manual_change.ngc is that the M73 when exiting the sub reverts the tool length offset (G43) to the state before the sub was executed, effectivly canceling out the tool length offset calculated in the sub for anything other than the reference tool.
- h_munktell
11 Dec 2012 05:41 #27540
by h_munktell
Replied by h_munktell on topic Remap M6 with "toolchange with length-probe"
Thanks for the replies, been a while, and now I have got the time to work on this and found a solution. The problem was that G49 was still in use when the probing started. And that screwed up things. I added just before the probing:
And now it works If it is a good solution I do not know, but works for me right now. But I think it would be great if there was a named parameter for the dynamic tool length offset.
; We need to cancel dynamic tool length offset before we probe. Save Z, G49 and restore Z to current coordinate system:
#1001=#5422
G49
G10 L20 P[#5220] Z[#1001]
11 Dec 2012 23:25 #27586
by mhaberler
well I rather think the demo was written by somebody who didnt proper check results
-m
Replied by mhaberler on topic Remap M6 with "toolchange with length-probe"
-m
The following user(s) said Thank You: bevins
- h_munktell
12 Dec 2012 03:59 #27599
by h_munktell
Well' I'm glad "somebody" did not, have learnt a great deal of linuxcnc because this Keep up the good work!
-m
Time to create page: 0.318 seconds
