some good advice (pid)
30 Oct 2012 23:00 - 30 Oct 2012 23:03 #26075
by jlviloria
Replied by jlviloria on topic some good advice (pid)
peter.
I've done this, the truth friend does not quite understand the concept.
please guide me a little more
thanks
thanks
Last edit: 30 Oct 2012 23:03 by jlviloria.
30 Oct 2012 23:38 #26082
by jlviloria
ultimate plot improved.
30 Oct 2012 23:56 #26084
Replied by PCW on topic some good advice (pid)
Thats quite a bit better and may actually be acceptable since this is a rapids move with rather aggressive acceleration and cutting moves will have lower velocities and accelerations
31 Oct 2012 01:03 #26087
by jlviloria
Peter,
I cut a little acceleration. tapeworm in the lead 800 to 600.
Watch these results.
one as defined proper acceleration.
how much would my maximum error right now.
31 Oct 2012 04:30 #26098
by jlviloria
peter,
What is the next step?
Or already set the PID?
And not I've noticed. LOL
thanks for all your cooperation
31 Oct 2012 04:41 #26099
Can you increase P any? it looks like its more stable now
After getting P set I would start adding some 'I' term gradually
31 Oct 2012 10:31 #26113
by jlviloria
Peter,
achieve P = 5. more oscillate the servomotors.
D try, but accomplish nothing positive. more oscillate the servomotors.
I tested "I". There was no improvement. one thing I noticed is that the value of "Z" was diminishing. with increasing "I"
peter. I'm far from achieving my servomotors tuning?
31 Oct 2012 10:37 #26115
I would not expect D to help much in s velocity mode servo (D is handled by the drive itself)
'I' may have to be fairly high before you see an effect
one way to adjust I is to add more until you get oscillation and then use about 1/2 to 1/3 the amount of I where oscillation started
Time to create page: 0.146 seconds
