Help to find problem in servo
13 Nov 2012 01:57 #26492
Replied by PCW on topic Help to find problem in servo
ferror and pid.n.error are in machine position units for a position loop
(PID error is difference in expected and real position)
so 5m/div = 5 microns per division if your machine is set up for MM
The PID output scaling will be in position units per second (its controlling a velocity)
14 Nov 2012 05:40 #26555
by aike
I did not find any pin/parameter witj this name in pid module.
Replied by aike on topic Help to find problem in servo
How to set this flag?
To see pid.N.error you need to set the PID comps debug flag
FF1 can be fine tuned when P is small (too much FF1 makes position lead profile, too little FF1 makes position lag profile) changes in FF1 should be very small (it will still be very close to one)
To eliminate the 1 or 2 encoder count dither when stopped, you can add some more deadband
14 Nov 2012 06:39 #26558
So loadrt pid …. debug=1
Replied by andypugh on topic Help to find problem in servo
www.linuxcnc.org/docs/html/man/man9/pid.9.html
How to set this flag?To see pid.N.error you need to set the PID comps debug flag
Time to create page: 0.153 seconds
