Errors when stopping program from pendant
15 Nov 2012 17:50 #26615
by Miselph
Errors when stopping program from pendant was created by Miselph
Hello,
I have built my own pendant which is interfaced via a userspace component. When I press the "Stop" button the machine stops but it also produces an error:
can't do that (EMC_TRAJ_SET_TELEOP_ENABLE) in auto mode with the interpreter idle
The input from the pendant is netted straight onto the halui.program.stop pin.
What do I need to do to get rid of this error?
15 Nov 2012 19:52 #26618
by BigJohnT
Replied by BigJohnT on topic Errors when stopping program from pendant
Does this error happen all the time or only when pressing the button when not actually running?
16 Nov 2012 00:23 #26632
by Miselph
Replied by Miselph on topic Errors when stopping program from pendant
Hi John,
I get the error only if I press stop when the machine is running. When the machine is stopped then there is no error.
Every now and again the error doesn't appear which makes me wonder if it is a timing issue, but I don't know enough about LinuxCNC's internal operations to know where to look.
Chris
Chris
16 Nov 2012 00:49 #26635
Some discussion here, but no solution as far s I can see,
comments.gmane.org/gmane.linux.distributions.emc.devel/1575
Replied by andypugh on topic Errors when stopping program from pendant
]can't do that (EMC_TRAJ_SET_TELEOP_ENABLE) in auto mode with the interpreter idle
16 Nov 2012 08:51 #26650
by BigJohnT
Have you seen this topic on run/stop buttons.
linuxcnc.org/index.php/english/forum/47-...p-holdresume-buttons
Time to create page: 0.197 seconds
