Guidance for remapping of a M-command
12 Dec 2012 05:29 #27604
by lugr
Guidance for remapping of a M-command was created by lugr
Hello everybody,
I would like to ask, whether anybody can provide me with a small step-by-step guide to remap a M-command?
I had already a look on the document "extending EMC", but I'm missing some sort of a "red line" in this document.
Can anybody tell me how to start with the remap of an M-command?
Thank you for your help!
12 Dec 2012 18:25 #27616
by ArcEye
Replied by ArcEye on topic Guidance for remapping of a M-command
Hi
Everything is in www.linuxcnc.org/docs/devel/html/remap/structure.html and referenced in various posts on this forum
Don't know what you mean by red line
The place to start is to download the master (2.6~prexxxxx), build it as a RIP system and read and follow the examples in there.
Of course you don't need to remap M codes if all you want to do is implement something new, rather than change the way an existing M code works
All you have to do is write one www.linuxcnc.org/docs/html/gcode/m-code....d_sec_m100_to_m199_a
The following user(s) said Thank You: lugr
12 Dec 2012 19:35 #27618
by mhaberler
Replied by mhaberler on topic Guidance for remapping of a M-command
lugr,
a complete remapping example with ini configuration and the matching NGC procedure can be found here:
3.3.1. Example for named parameter passing to NGC procedures
which is in this section: www.linuxcnc.org/docs/devel/html/remap/s..._argspec_parameter_a
- Michael
- Michael
12 Dec 2012 21:59 #27624
I _think_ you can remap in a pre-packaged and installed "Master" version from the buildbot, and that's rather easier.
Replied by andypugh on topic Guidance for remapping of a M-command
12 Dec 2012 23:07 #27631
by lugr
Replied by lugr on topic Guidance for remapping of a M-command
Hi all,
Thank you for your quick responses. I've access to the GIT-server and I've already downloaded the files from there.
Do I just have to make some changes in the [PYTHON]-section in the xxx.ini-file according to the example from mhaberler or do I have to install something else?
12 Dec 2012 23:11 #27632
by mhaberler
Hi lugr
If you are just starting I'd really recommend you install the buildbot master package instead of building yourself, see buildbot.linuxcnc.org/
Just try the example exactly as it is in the manual - it doesnt say anything about [PYTHON] and that is because that example does not need it.
Also explore the canned examples under configs/sim/remap .
- Michael
Hi all,
Hi lugr
- Michael
13 Dec 2012 01:22 #27637
by major
Replied by major on topic Guidance for remapping of a M-command
hello michael,
I'm a collegue from lugr and try to install the buildbot master package.
in the description it is reffered to a path
/etc/apt/sources.list.d/linuxcnc-buildbot.list.
But the last argument "linuxcnc-buildbot.list" is not existing on my machine. how do I get the two lines
(deb buildbot.linuxcnc.org/ lucid v2.5_branch-sim
deb-src buildbot.linuxcnc.org/ lucid v2.5_branch-sim)
to that list?
Is linuxcnc-buildbot.list just a textfile which contains the two lines or what exactly do I have to do?
Thanks,
Thomas
hello michael,
to that list?
Thanks,
Thomas
13 Dec 2012 01:53 #27638
by mhaberler
Thomas,
this is a generic linux question and you will get better support on say ubuntu forums
that said: please read 'man sources.list' - yes it is a text file, and yes you have to add it
- Michael
hello michael,
to that list?
Thanks,
Thomas
Thomas,
- Michael
13 Dec 2012 01:55 #27639
by mhaberler
you do NOT want these lines, you are trying to install master, not 2.5:
you want these, assuming you want a simulator build:
deb buildbot.linuxcnc.org/ lucid master-sim
deb-src buildbot.linuxcnc.org/ lucid master-sim
- Michael
- Michael
13 Dec 2012 02:16 #27640
by major
______________________________________________________________________________________________________________
I could manage it to get the master-sim data. But when I start one of the sample configurations under the remap section, linuxcnc aborts with the following error message
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.0-pre0-3568-gc20e22f
Machine configuration directory is '/home/major/linuxcnc/configs/sim/remap/getting-started'
Machine configuration file is 'demo.ini'
INIFILE=/home/major/linuxcnc/configs/sim/remap/getting-started/demo.ini
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=axis
DISABLE_SERVER=
SERVER_PATH=
SERVER_ARGS=
SERVER_LOG=
Starting LinuxCNC...
Starting redis server program:
redis server started as: 'redis-server ', logging to: /dev/null
io started
halcmd loadusr io started
Killing task linuxcncsvr, PID=4877
Killing task redis-server, PID=4876
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
Can not find -sec REDIS -var DISABLE_SERVER -num 1
Can not find -sec REDIS -var SERVER_PATH -num 1
Can not find -sec REDIS -var SERVER_ARGS -num 1
Can not find -sec REDIS -var SERVER_LOG -num 1
Could not open command file '../../core_sim.hal'
4877
PID TTY STAT TIME COMMAND
4876
Stopping realtime threads
Unloading hal components
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
TASK=milltask
HALUI=halui
DISPLAY=axis
DISABLE_SERVER=
SERVER_PATH=
SERVER_ARGS=
SERVER_LOG=
io started
Cleanup done
4877
4876
