Velocity 5axis
06 Feb 2013 00:39 #29651
by Mr_Wolfs
Velocity 5axis was created by Mr_Wolfs
06 Feb 2013 02:09 #29660
That is what that entry means.
You need to choose a value that suits the slowest axis.
Then any linear move in any direction can be achieved at the programmed rate, up to that limit.
Replied by andypugh on topic Velocity 5axis
I built a 5 axis machine, all works but I have a problem with the velocity.
When I'm in world mode (teleop) the Z axis take the velocity of the MAX_LINEAR_VELOCITY in the [TRAJ] section.
06 Feb 2013 02:16 #29661
by Mr_Wolfs
Replied by Mr_Wolfs on topic Velocity 5axis
Then you say me that I must put MAX_VELOCITY = 10 to all linear axis.
It's bad I could go faster with my machine.
06 Feb 2013 02:28 #29664
No, you can use the maximum velocity in the indvidual axis sections, and that will be the velocity used in joint-mode moves.
However in world mode there is only one maximum speed, and that is governed by the speed of the slowest axis. This is a consequence of how the velocity limiitation is done.
06 Feb 2013 02:41 - 06 Feb 2013 02:42 #29665
by Mr_Wolfs
ok but it's strange cause when I start a gcode, the Z axis move faster than in joint-mode.
the tool path doesn't follow the good trajectory.
We can't change the velocity limitation in world mode?
Last edit: 06 Feb 2013 02:42 by Mr_Wolfs.
06 Feb 2013 02:54 #29666
I wonder if it related to the fact that you have a STEPGEN_MAXVEL defined for the Z axis, but not for any other?
Bear in mind that it will try to make the tool tip follow the programmed path, and if the tool length is wrong or the 5axiskins offsets are wrong then the resulting path will be wrong.
That is strange.ok but it's strange cause when I start a gcode, the Z axis move faster than in joint-mode.
I am not at all familiar with 5axiskins.We can't change the velocity limitation in world mode?
06 Feb 2013 16:25 #29691
by Mr_Wolfs
No the STEGEN_MAXVEL defined for the Z axis was a test but I can't see the difference with it.
My 5axiskins is set up correctly I have the good tool length for my machine.
07 Feb 2013 04:56 #29733
I am afraid that I have reached the limit of my knowledge with 5axiskins.
You might find better help on the mailing list of the IRC channel.
See the "Community" link at the top.
07 Feb 2013 05:30 #29737
by Mr_Wolfs
It's not a problem thanks for your help
13 Feb 2013 06:59 #29988
by Mr_Wolfs
Time to create page: 0.096 seconds
