Scarakins , changing the arm specs
- brianTruck
- Thank you received: 7
22 Feb 2013 04:52 #30426
by brianTruck
Scarakins , changing the arm specs was created by brianTruck
Hi all,
I just got my scara robot running on LinuxCNC , but have one little problem.
How do you change the scarakin.D1 ,scarakin.D2 ,ect. I want to change the length of my arms
Thanks'
Brian
Thanks'
Brian
22 Feb 2013 20:01 #30447
by ArcEye
Replied by ArcEye on topic Scarakins , changing the arm specs
Hi
I had to load the module and examine it to be sure, the documentation is rubbish, does not even say what hal type the pins are, albeit I could guess float.
The hal command you want is
setp scarkins.D1 nnn.nnnnnn
ie the value is a floating point value you can set or amend with setp (set pin or param)
It looks as though there are default values already
D1 490
D2 340
D3 50
D4 250
D5 50
D6 50
TIP: If you ever want to look at a module like this and experiment , from a terminal run something like
halrun
halcmd: loadrt scarkins
halcmd: show all
halcmd: setp scarakins.D1 465.204
halcmd: show all
halcmd: unloadrt scarakins
halcmd: exit
see man halrun for more options
D1 490
D2 340
D3 50
D4 250
D5 50
D6 50
halrun
halcmd: show all
halcmd: show all
halcmd: exit
The following user(s) said Thank You: brianTruck, Boogie
- brianTruck
22 Feb 2013 22:20 #30452
by brianTruck
Replied by brianTruck on topic Scarakins , changing the arm specs
Cool,
Thank You ! works great.
Now for the next problem ,the scara gui arms are now too short .I opened the scara gui in gedit and changed the arms ,but can't save it.
Thanks'
Brian
Thanks'
Brian
22 Feb 2013 22:46 #30453
by ArcEye
sudo gedit
- brianTruck
23 Feb 2013 00:55 #30458
by brianTruck
ArcEye,
Thanks , I'm just starting to get my feet wet with Linux.
Brian
Brian
