usb web cam - axis cross hairs
- Tchefter
- Thank you received: 32
15 Aug 2015 20:17 #61410
by Tchefter
Hi ArcEye,
is it possible to tell me more about how this should work. Sorry for the lot of question, but i'm still a beginner.
thank you,
regards fritz
Replied by Tchefter on topic usb web cam - axis cross hairs
Hi
If you want a DRO visible, you can always use 3 number display widgets in a pyvcp panel and net them to Xpos, Ypos, Zpos
Hi ArcEye,
thank you,
regards fritz
- BigJohnT
- Thank you received: 1176
16 Aug 2015 19:09 #61432
by BigJohnT
Replied by BigJohnT on topic usb web cam - axis cross hairs
First you might read about the net command and signals here:
www.linuxcnc.org/docs/2.7/html/hal/basic-hal.html
Then read about the display widgets here:
www.linuxcnc.org/docs/2.7/html/gui/pyvcp.html
So for example if you had a signal named xpos (you would have to look at your configuration to see what the actual name is) then you could net that signal to a number display reader. Look at the diagram in the basic hal chapter.
JT
JT
The following user(s) said Thank You: Tchefter
- Tchefter
16 Aug 2015 19:18 #61433
by Tchefter
Thank you John!
think, should be possible for me
regards fritz
regards fritz
Time to create page: 0.062 seconds
