siemens 6SC6101 question
14 Mar 2013 00:19 #31345
by jlviloria
siemens 6SC6101 question was created by jlviloria
good morning, I have the following question. I have 4 Siemens 1FT5 servomotors and servo controller 6SC6101 controller 4 axis, but I notice that in the original machine configuration of the encoder cable go directly to the servo controller at siemens 6SC6101 and not to numerical control, in this case I can not use my 7i77 to control servomotors such?
Any idea if it is possible to adjust my servocontroller with mesanet 7i77?
thanks.
Jorge Viloria
thanks.
Jorge Viloria
14 Mar 2013 01:03 - 14 Mar 2013 01:03 #31350
Replied by PCW on topic siemens 6SC6101 question
Looks like the motors do not have normal encoders but rather some kind absolute encoder just used for commutation. My guess is that these were used with external encoders for controller feedback so you would probably have to add encoders for feedback.
Last edit: 14 Mar 2013 01:03 by PCW.
The following user(s) said Thank You: jlviloria
14 Mar 2013 01:37 #31355
by jlviloria
Replied by jlviloria on topic siemens 6SC6101 question
Peter, thanks for your response. has the same encoder to use with my first machine which you helped me a lot,
Has this encoder in servomotors:
www.beiied.com/PDFs2/H25_Incremental_Encoder.pdf
you think you only connect the encoder to the 7i77 and done?
Not compatible with 7i77?
I appreciate your attention.
14 Mar 2013 02:04 #31357
That encoder should be compatible but the drive manual I could find used a different encoder type that only goes to the drive. Do you have the exact drive manual?
14 Mar 2013 02:27 #31359
by jlviloria
if I have manual servo. how to define if it is compatible with my 7i77?
is that the question is rather silly but I really do not know how to define if it is possible to retrofit this servodrives
thanks.
thanks.
14 Mar 2013 02:31 #31360
The 6SC6101 I looked up is a analog velocity mode servo which is compatible with the 7I77 but would need an additional encoder
www.rgbelektronika.pl/shop/pl/p/file/abd...0-SIEMENS-MANUAL.pdf
14 Mar 2013 03:56 #31365
by jlviloria
thanks.. Peter. solved.
Time to create page: 0.071 seconds
