gantry kinematics dual Y
05 May 2013 18:05 #33647 by juwi
gantry kinematics dual Y was created by juwi
Hi
will the attached kinematics work as dual Y Axis gantry setup?
i changed in trivkins:
int kinematicsForward(const double *joints,
EmcPose * pos,
const KINEMATICS_FORWARD_FLAGS * fflags,
KINEMATICS_INVERSE_FLAGS * iflags)
pos->tran.x = joints[0];
pos->tran.y = joints[1];
pos->tran.z = joints[3];
pos->a = joints[4];
pos->b = joints[5];
pos->c = joints[6];
pos->u = joints[7];
pos->v = joints[8];
pos->w = joints[8];
return 0;
int kinematicsInverse(const EmcPose * pos,
double *joints,
const KINEMATICS_INVERSE_FLAGS * iflags,
KINEMATICS_FORWARD_FLAGS * fflags)
joints[0] = pos->tran.x;
joints[1] = pos->tran.y;
joints[2] = pos->tran.y;
joints[3] = pos->tran.z;
joints[4] = pos->a;
joints[5] = pos->b;
joints[6] = pos->c;
joints[7] = pos->u;
joints[8] = pos->v;
joints[8] = pos->w;
return 0;
Or am I messing up something else this way?
best regards
06 May 2013 19:49 #33671 by alan_3301
Replied by alan_3301 on topic gantry kinematics dual Y
I'm not sure, and don't understand how any of that works, But...
I think inverse kinematics has to be exactly that, inverse of forward kins.
So it might fail compile, or give unpredictable results. Not sure..
Have you tried connecting Y step and dir to 2 sets of pins for 2 drives?
06 May 2013 20:20 #33672 by juwi
Replied by juwi on topic gantry kinematics dual Y
Ok, some more information.
I am running a 7i77 servo setup with velocity drives. I have it up and running, but cannot use the screw compensation the way I did it.
Gantry config is ignoring Softlimits...
By using the above kinematics I tried to use 2 Joints for the Portal that are fixed Linked to the Y axis.
That will allow me to use a screw comp for each side of the portal.
best regards
07 May 2013 14:04 #33702 by juwi
Ok, tried it yesterday.
After changing identity to KINEMATICS_BOTH it works with gcodes.
Jogging with the Keyboard is not working. Why? The keyboard jogging seems to ignore the Kinematics and drives the axis directly?
Best regards
Time to create page: 0.050 seconds
