Setup of a MPG for gantry
- malare
28 May 2013 01:31 #34775
by malare
Setup of a MPG for gantry was created by malare
How do you setup a MPG to work in World mode so you can jog a gantry x-axle?
All other axes works fine to jog with the MPG.
Many regards Per Malare
- Thank you received: 5015
28 May 2013 08:08 #34805
It ought to just work (in World mode). You really don't want to be jogging a gantry in Joint mode.
How have you connected the MPG in HAL?
Replied by andypugh on topic Setup of a MPG for gantry
- malare
28 May 2013 15:51 #34815
by malare
Replied by malare on topic Setup of a MPG for gantry
I can only send you the hal-file so you can look at it. I don't really know myself how things are done.
It's my son who is an expert on these things. He has used a file we found as a template, and made changes in it.
As you can see from the file-name we use a MESA 5i25 card for driving Gecko G540 drivers but the MPG is connected to an extra PCI parallell card.
- malare
28 May 2013 16:03 #34816
by malare
There was another hal-file too
Perhaps the ini-file is useful too
28 May 2013 20:31 #34836
i will need to experiment with a configuration, which I can't do until this evening.
(I can see a way to do it, but I think it might be the wrong way)
30 May 2013 07:55 #34939
It took longer than I expected to get to this.
I have created a simulator config which I can test with. I can confirm that it won't jog for me in World mode either. (thou in my case I can't jog any axis)
Unfortunately I am out of time for tonight. More tomorrow.
30 May 2013 08:12 #34940
A bit more on this.
www.linuxcnc.org/docs/html/man/man9/gantrykins.9.html
Says that incremental jogging doesn't work in World mode.
I think there is a way round this, using the jogwheel speed as a velocity-jogging request. But I need some time to see what that takes.
- malare
01 Jul 2013 01:23 #36178
by malare
Have you had time to look into it?
01 Jul 2013 07:07 #36181
Yes, and no. I have had the time. But I forgot. I feel rather guilty now.
I have taken on a big chunk of work on re-coding how LinuxCNC handles tools. I expect to be busy with that for many months now.
Is my idea of using the encoder velocity to control a velocity-mode jog enough of a clue to get you started by yourself?
Look at the halui.jog.N.analog pins here:
www.linuxcnc.org/docs/html/man/man1/halui.1.html
Time to create page: 0.377 seconds
