Mixed Servo and Stepper system
- mariusl
11 Jun 2013 03:51 #35504
by mariusl
Regards
Marius
www.bluearccnc.com
Mixed Servo and Stepper system was created by mariusl
Hi All,
Is there any reason why I could not have a mixed stepper / servo system? I may have to add a stepper driven axis to a servo driven 5 axis machine.
Regards
Marius
www.bluearccnc.com
- cncbasher
- Thank you received: 288
11 Jun 2013 13:54 #35519
by cncbasher
Replied by cncbasher on topic Mixed Servo and Stepper system
no reason at all , many people do just that for situations such as adding a rotary table .
which axis are you looking at adding , perhaps details of your problem , may throw some questions
- mariusl
11 Jun 2013 14:08 #35521
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Mixed Servo and Stepper system
I have a machine that has the x axis as the material. Meaning that we pull the material up and down with rollers. The material could be 13m long beams that could weigh more than a ton each. We discovered that the movement is not always predictable due to variances in the material. The PID tuning also keeps changing with every job as the the material could vary from 20kg to a ton or more. Not a good situation to try and do good PID control. The solution is to add a trolley to the x axis that will be driven by a stepper on a rack and pinion and that will now move the material through the machine under control.
I am looking at a 30nm stepper possibly.
Regards
Marius
www.bluearccnc.com
- cncbasher
11 Jun 2013 14:36 #35522
by cncbasher
yea you should be ok to go , although i'd perhaps look at using 2 steppers one each side ( without knowing or seeing the offending machine of course )
Dave
Dave
- mariusl
11 Jun 2013 15:21 #35523
by mariusl
Regards
Marius
www.bluearccnc.com
Thanks for the advise Dave. The nature of the machine is such that we cannot get into the area where the operations happen. That is about 2m wide cage that contains the z axis head (600kg worth) and the Y axis. There are two roller conveyors of 14m each on both sides. The closer rollers are powered and I use them to bring the material into range. That will change now. The trolley will have an arm to push the material into the machine. We will most likely use an electro-magnet to hold or connect to the material
Regards
Marius
www.bluearccnc.com
- cncbasher
11 Jun 2013 20:05 #35530
by cncbasher
yes i'd agree .. i'd use magnets
Time to create page: 0.056 seconds
