want 9 axes; STEPGEN outputs only 8 channels?
11 Jul 2013 04:06 #36534 by niftyEnt
Replied by niftyEnt on topic want 9 axes; STEPGEN outputs only 8 channels?
Also...
I need to install the custom UVWkins.c file for the RIP version.
when I enter:
tom@shop:~/linuxcnc-dev/configs/UVW$ sudo comp --install UVWkins.c
[sudo] password for tom:
make KBUILD_EXTRA_SYMBOLS=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/Module.symvers -C /usr/src/linux-headers-2.6.32-122-rtai SUBDIRS=`pwd` CC=gcc V=0 modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.32-122-rtai'
CC [M] /tmp/tmpOmD2iU/UVWkins.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/tmpOmD2iU/UVWkins.mod.o
LD [M] /tmp/tmpOmD2iU/UVWkins.ko
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-122-rtai'
cp UVWkins.ko /usr/realtime-2.6.32-122-rtai/modules/linuxcnc/
comp is obviously installing at ~/linuxcnc/ instead of ~/linuxcnc-dev/ and running:
tom@shop:~/linuxcnc-dev$ linuxcnc
LINUXCNC - 2.6.0~pre
Machine configuration directory is '/home/tom/linuxcnc/configs/UVWdev'
Machine configuration file is 'UVW.ini'
Starting LinuxCNC...
io started
halcmd loadusr io started
UVW.hal:4: Can't find module 'UVWkins' in /home/tom/linuxcnc-dev/rtlib
Is there some way to force comp to install in the correct directory?
11 Jul 2013 04:11 - 11 Jul 2013 04:12 #36535 by BigJohnT
Replied by BigJohnT on topic want 9 axes; STEPGEN outputs only 8 channels?
thanx Basher,
That did the trick.
I can launch linuxCNC from Terminal with:
but the configurations offered are from the stock version at:
tom@shop:~/linuxcnc$
Any idea how I point the config screen to the config folder at tom@shop:~/linuxcnc-dev?
Open a terminal and change to your dev directory then do
. ./scripts/rip-environment
from the same terminal
linuxcnc
The rip-environment script sets up that session to point to the RIP install.
comp --install will put the files into the installed directory. For a RIP you place the file in /src/hal/components and build.
JT
Last edit: 11 Jul 2013 04:12 by BigJohnT.
11 Jul 2013 04:49 #36536 by niftyEnt
Okay JT,
I copied UVWkins.c to tom@shop:~/linuxcnc-dev/src/hal/components
I started a fresh terminal and entered:
tom@shop:~/linuxcnc-dev$ . ./scripts/rip-environment
then:
tom@shop:~/linuxcnc-dev/src/hal/components$ sudo comp --install UVWkins.c
CC [M] /tmp/tmpEVJmYq/UVWkins.o
MODPOST 1 modules
CC /tmp/tmpEVJmYq/UVWkins.mod.o
LD [M] /tmp/tmpEVJmYq/UVWkins.ko
tom@shop:~/linuxcnc-dev/src/hal/components$ c
then:
io started
Cleanup done
LinuxCNC terminated with an error. You can find more information in the log:
/home/tom/linuxcnc_debug.txt
and
/home/tom/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
I'm still getting the stock config splash screen, and UVWkins does not exist in:
The . ./scripts/rip-environment script does not seem to be resetting the $PATH.
More suggestions?
11 Jul 2013 05:33 #36537 by niftyEnt
except that it is:
tom@shop:~/linuxcnc-dev/configs/UVW$ echo $PATH
/home/tom/linuxcnc-dev/bin:/home/tom/linuxcnc-dev/scripts:/home/tom/linuxcnc-dev/tcl:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
11 Jul 2013 05:42 #36538 by niftyEnt
SO!
I manually copied:
~ /usr/realtime-2.6.32-122-rtai/modules/linuxcnc/UVWkins.ko
to:
~/linuxcnc-dev/rtlib
then launched from tom@shop:~/linuxcnc-dev/linuxcnc
and AXIS has loaded. I'm still getting the stock config splash screen, but I'm going to play with what I've got and see if the kins are correct.
not a very elegant work-around, but...
If you guys have any other ideas, please post.
many thanks to JT and cncbasher
niftyEnt
11 Jul 2013 19:03 - 11 Jul 2013 19:07 #36551 by BigJohnT
Looks like you skipped the build step after copying the component to the tom@shop:~/linuxcnc-dev/src/hal/components.
After copying you need to go to the /src directory and rebuild and setuid then run the RIP script from the /linuxcnc-dev directory.
comp --install installs to the installed directory not the rip directory, you only use that if your running the installed version.
Once you get it to work manually then create a script to launch it from the desktop.
JT
Last edit: 11 Jul 2013 19:07 by BigJohnT.
