joint_axes3 and gentrivkins
  • grandixximo
  • grandixximo's Avatar Topic Author
  • Premium Member
  • Premium Member
10 Aug 2013 13:31 #37539 by grandixximo
joint_axes3 and gentrivkins was created by grandixximo
I want to build a machine with a gantry Y axis.
I have try the normal gantrykins confing and it works but it's not really a nice implementation, i can't figure out how to slow down the Z axis when jogging in axis mode (in joint mode it respects the ini file maximum speed in axis mode it doesn't, for what reson i don't know). the other problem is with the machine limit, which are not as neat as usual, where the machine will not jog over the limit no matter what, with gantrykins the machine will have message popping up exceed soft limit, but then you can keep jogging past the limit, which is bad.
so i have searched and looked, and found some posts about the gentrivkins in joint_axes3 branch which works much more nice, always in axis mode and with good working limits.
i just can't figure out how to set the .ini and .hal file properly.
is there a sample configuration for a gantry using gentrivkins instead of gantrykins?
my problem right now is the connection between axis and joints.
what i mean is like gantrykins where you write
loadrt gantrykins coordinates=axisletters
to set up which axis is which joint.
how do i do it with gentrivkins?
  • grandixximo
  • Premium Member
  • Premium Member
18 Aug 2013 08:36 - 18 Aug 2013 08:37 #37795 by grandixximo
Replied by grandixximo on topic joint_axes3 and gentrivkins
Where can i get some support or advice for joint-axes and gentrivkins?
Last edit: 18 Aug 2013 08:37 by grandixximo.
18 Aug 2013 18:08 #37806 by BigJohnT
Replied by BigJohnT on topic joint_axes3 and gentrivkins
The mailing list might be the best place to ask about this.
JT
  • grandixximo
  • Premium Member
  • Premium Member
05 Nov 2013 14:53 - 05 Nov 2013 16:19 #40545 by grandixximo
I did try with the mailing list, no one reply..
I'm starting to think this might be a bug.
I have been searching and everyone seems to have get it to work without much questions, I don't get why I can't
I got snapshots from github of both source for joint_axes3 and joint_axes4 and in both it ain't working.
Please I need some help...
I have zipped and attached the configurations files I'm using to test, they are from the original axis sim, i have made changes to have them working with ja3
Open the gantry.ini or axis_mm.ini for testing.
I think I have setup everything right but the axis won't move correctly.
i setup the coordinates of gentrivkins=XYYZ
If this is working like gantrykins, and for what i have read it should, then;
X=JOINT_0
Y=JOINT_1&2
Z=JOINT_3
But if you run my attached configuration, you'll see that it is not like that, moving X will move joint 0 and so X will move, and this is OK, then moving Y will move joint 1 and nothing will move in axis interface, moving Z will move joint 2 and in axis Y will move.
to see this watch the joints pos-cmd of the four joints, move the axis, and look at what axis moves on the axis displayed position.
I have try everything i can think of, it just doesn't work....
Last edit: 05 Nov 2013 16:19 by grandixximo.
06 Nov 2013 07:07 #40567 by andypugh
Replied by andypugh on topic joint_axes3 and gentrivkins
Which actual INI file are you running? That config seems to contain all of sim_axis, so it's a bit hard to tell which files to look at.
If you are using gantry.ini then that references gantrysim.hal, and that has
loadrt gentrivkins coordinates=XXYZ
Which isn't the XYYZ you said you wanted.
  • grandixximo
  • Premium Member
  • Premium Member
08 Nov 2013 08:24 - 08 Nov 2013 08:26 #40653 by grandixximo
File Name: axis.zip
File Size:9 KB
I cleaned the configs, axis_mm.ini is kinda like what I am trying to do, gantry.ini is just the original gantry that was working with the gantrykins, changed to gentrivkins.
both configs work properly if the kinematics is changed to gantrykins.
Last edit: 08 Nov 2013 08:26 by grandixximo.
Time to create page: 0.095 seconds
