Checking hal pin from NGC?
18 Sep 2013 00:21 #38950 by machete
Checking hal pin from NGC? was created by machete
Hello!
I am trying to folow this example, from here:
www.linuxcnc.org/docs/devel/html/remap/structure.html
o100 if [EXISTS[#<_hal[motion-controller.time]>]]
  (debug, [motion-controller.time] exists: #<_hal[motion-controller.time]>)
o100 else
  (debug, [motion-controller.time] does not exist)
o100 endif
But with any hal-pin it always show me "does not exist", or if i just try to debug it's value "######".
My version of LinuxCNC: 2.6.0
P.S. I want to have ability to do, or not to do part of NGC program (tool changing) depending on output pin of Classic Ladder.
18 Sep 2013 06:35 #38964 by andypugh
Replied by andypugh on topic Checking hal pin from NGC?
You need to turn on the feature of reading HAL pins from g-code:
www.linuxcnc.org/docs/devel/html/remap/s...d_sub_ini_features_a
18 Sep 2013 14:50 - 18 Sep 2013 14:50 #38976 by machete
Replied by machete on topic Checking hal pin from NGC?
Thank you!
enable #<_hal[Hal item]> readonly variables: 8
if set, the interpreter will fetch read-only values from HAL file through this special variable syntax.
Is that correct?
[RS274NGC]
FEATURES = 8
Last edit: 18 Sep 2013 14:50 by machete.
18 Sep 2013 17:03 #38980 by andypugh
Is that correct?
[RS274NGC]
FEATURES = 8
Yes, though you might want to use FEATURES=12 to get access to INI file parameters too.
25 Sep 2013 21:02 #39181 by machete
Hmm... i wasn't able to get any #<_hal[hal-pin]> value before executing M66 g-code!
(i spent two days to understand that)
So, here is my correctly working NGC program for tool changing:
o<mytoolchange> sub
M66 P3 L0 Q0 			(asking Classic Ladder is tool change needed?)
			          (flag from classic ladder)
(#debug, [5399]: #5399 - showing OK!)
(#debug, [skip-tool-change]: #<_hal[skip-tool-change]> - also showing OK!)
o100 if [#5399]
	(debug, Skip changing tool!)
	M6			(just legalize it for system)
o100 else
	(debug, Changing.)
	M5			(stop spindle)
	G0 G53 Z75.1 		(go to plane of Tool Magazine's clamps)
	M64 P0 			(enabling DO-CHANGE bit for classic ladder)
	M66 P0 L3 Q2678400	(waiting 1 month for PHASE2 signal when)
	G0 G53 Z205.3 		(go back to left tool in the clamp)
	M66 P1 L3 Q2678400	(waiting 1 month for PHASE3 signal)
	G0 G53 Z75.1		(go to plane of Tool Magazine's clamps Y75.5)
	M66 P2 L3 Q2678400	(waiting 1 month for CHANGED)
	M65 P0			(disabling DO-CHANGE bit)
	M6			(acting loopbacks)
o100 endif
o<mytoolchange> endsub
M2
Time to create page: 0.070 seconds
