Trouble adding an A axis
- garymcrobertpdx
22 Sep 2013 00:41 #39082
by garymcrobertpdx
Trouble adding an A axis was created by garymcrobertpdx
I have added an A axis to rotate work pieces under the spindle tool.
Things mostly work but I am experiencing fallowing errors with this
axis when I attempt to increase the rotational velocity.
I have checked the HAL and integrators manuals concerning HAL
variables maxaccel, maxvel and INI variables MAX_VELOCITY & MAX_ACCELERATION. I have tried using the pncconf wizard as a
way of learning how this works. But I still can not spot the problem.
How do the maxaccel, maxvel, MAX_VELOCITY & MAX_ACCELERATION variables relate to one another? or are there other variables I have
over looked? I am having trouble understanding this
I am using a Mesa 5i25 IO board to drive the step motor with no
feedback loop so I should be able spin this axis rather fast.
- garymcrobertpdx
22 Sep 2013 01:18 #39084
by garymcrobertpdx
Replied by garymcrobertpdx on topic Trouble adding an A axis
Some other observations :
If I relax FERROR to = 0.010 I can set the feed rate F30000 and G1 A1000
The axis will spin up to the max velocity 21600 deg/min or 360 deg/ sec
this is as it should be and works fine.
But if HOME_SEARCH_VEL is greater than 12.00 deg/sec I get a joint
fallow error when homing.
Or if I attempt to jog the A axis at a speed greater than about 600 deg/min
I get a joint fallow error.
- Thank you received: 5270
22 Sep 2013 01:48 #39085
Replied by PCW on topic Trouble adding an A axis
On thing to remember if you change acceleration is that
the stepgen maxaccel parameter must be about 1.2 x the machines MAX_ACCELERATION value for each axis
- garymcrobertpdx
22 Sep 2013 03:59 #39093
by garymcrobertpdx
Tried another approach I let Pncconf generate a complete new configuration
letting it compute all the values in the INI and Hal files.
This did not solve the problem when I attempt to home the A axis it
begins the cycle but generates an fallow error near the end of home
process.
process.
22 Sep 2013 04:47 #39096
I would verify that the stepgen maxvel and maxaccel values are correct in the ini/hal files
- garymcrobertpdx
22 Sep 2013 07:45 #39098
by garymcrobertpdx
Here are the values created via the Pncconf wizard
setp hm2_5i25.0.stepgen.08.maxaccel 1350.0
setp hm2_5i25.0.stepgen.08.maxvel 450.0
MAX_VELOCITY = 360.0
MAX_ACCELERATION = 1080.0
1350.0 / 1080.0 = 1.25
450.0 / 360.0 = 1.25
They seem correct as per your comment about the 1.2 ratio
22 Sep 2013 09:00 #39099
In that case its probably higher up
(the axis may be requested to do a motion its not capable of)
I do recall that DEFAULT_ACCELERATION needs to be set for
non-trivial kinematic machines
- garymcrobertpdx
24 Sep 2013 04:26 #39150
by garymcrobertpdx
Would the DEFAULT_ACCELERATION be set in the TRAJ section of the INI file?
would it equal setp hm2_5i25.0.stepgen.08.maxaccel 1350.0 or
MAX_ACCELERATION = 1080.0 or some value in between?
A solution to this problem has become of great importance since
I am now experiencing fallow errors during G1 Annn moves thus
preventing useful work.
- Thank you received: 4994
24 Sep 2013 18:32 #39153
I think this is probably a trivikins machine. (especially if Pncconf is being used).
How many steps per second do you need at the programmed A-axis speed? How long are step-space and step-time?
Replied by andypugh on topic Trouble adding an A axis
- garymcrobertpdx
25 Sep 2013 04:42 #39168
by garymcrobertpdx
The top step rate is 72Khz, should be a piece of cake for the Mesa 5i25.
The drive is a quite happy with 1us pulse widths and probably can accept
a 200Khz step rate or more, never tried to find out.
But this problem is not a hardware issue. Since there is no feedback in
the system other than homing switches and the spindle encoder Linuxcnc
is unaware of what the X Y Z & A axis are actually doing.
By experiment I have stumbled onto a solution that appears to solve the
problem. If I change MIN_FERROR = 0.0005 to MIN_FERROR = 0.0010
and FERROR = 0.005 to FERROR = 0.1000 for the A axis the problem
disappears.
This may affect the positional accuracy of this axis but is small enough
that it has not caused a problem and way better than not working at all.
disappears.
Time to create page: 0.101 seconds
