Sharing changes in the source code
  • emcPT
  • emcPT's Avatar Topic Author
  • Platinum Member
  • Platinum Member
29 Dec 2013 16:36 #42141 by emcPT
Sharing changes in the source code was created by emcPT
Hello.
I never used git except to download the source code. I do not know how to share the changes that I did. I believe that I must use git push, but at the same time I suspect I do not have permissions to do that, so my question is how to upload the changes that I did so that they will be checked and accepted?
Changes objective:
Add the possibility to the user, using the .ini file, to change how linuxcnc uses the tool orientation: linuxcnc standard (that is used since implementation) or Fanuc standard (that is used by standard in all other controls). Basically the tool tip directions, that can be found here:
linuxcnc.org/docs/html/lathe/lathe-user.html
are swapped for positions 2-3; 8-6; 4-1
The changes were made on:
tool_parse.cc, tool_parse.hh, ioControl_v2.cc, ioControl.cc, driver.cc
How the user can use the feature:
Simply add to the EMCIO section of the .ini file a line containing:
FANUC_TOOLTIP_ORIENTATION = 1
It does not changes the behavior, if the previous line is not added, so it should be safe for all those that do not want to use the feature.
I also take the chance to ask, what GUI you people use to open the source code and browse though the code (like visual studio on windows)?
I made the changes only using VIM, and it is quite hard to browse in the code this way.
29 Dec 2013 17:25 #42143 by cmorley
Replied by cmorley on topic Sharing changes in the source code
Here is linuxcnc's new docs on development with git:
linuxcnc.org/docs/2.5/html/code/Contributing-to-LinuxCNC.html
heres the old one with some small examples:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Git
It's pretty technical for a newbee and doesn't tell you about using git it's self (though it mentions tutorials)
Roughly:
When you are happy with your editing of files:
you must commit your changes (git commit <file path>) to your branch of all the pertinent files (This only changes YOUR repository)
when you are happy with all your commits and want to share you have a couple options
If it's relatively small make a patch file. see here for an idea of that:
ariejan.net/2009/10/26/how-to-create-and...ly-a-patch-with-git/
since you don't have push rights to linuxcnc and are probably editing master branch:
first check if the branch you are using is in fact master, in a terminal in the linuxcnc repository folder type
git branch
That will probably say master (the one with an asterisk)
if so then the command to build a patch would be:
git format-patch origin/master --stdout > my_patch_name.patch
that command compares your branch to linuxcnc's branch (origin/master) and makes a patch of the different commits.
You want to make sure you master branch is current with git pull --rebase first.
which pulls in all the new stuff from origin/linuxcnc and puts your new stuff on top of that.
You could then mail that patch file
If it's large then pushing to a public repository and asking people to pull is the norm.
eg github
Next get on emc dev maillist.
plead your case there.
often you will get little response - if people don't feel qualified about the changes they tend not to answer.
unfortunately we do not have a formal way to consider patches.
There is a lot I left out, but I'm not sure what exactly you need to know..
Chris M
  • emcPT
  • Platinum Member
  • Platinum Member
29 Dec 2013 20:09 #42150 by emcPT
Replied by emcPT on topic Sharing changes in the source code
I post the patch here.
I hope it is done correctly. If I did something wrong please let me know.
to use the feature, on the EMCIO of the ini file, place:
30 Dec 2013 21:34 #42198 by andypugh
Replied by andypugh on topic Sharing changes in the source code
I use Eclipse.
www.eclipse.org
The C / C++ version with the Python plugin seems to cover most of LinuxCNC.
Time to create page: 0.051 seconds
