axis jumps on servo amp initialization
- jtc
- Thank you received: 13
13 Jan 2014 16:46 #42690
by jtc
axis jumps on servo amp initialization was created by jtc
hi!
I have a problem. when I start the machine for the first time and the servo drives need initialization (don't use hal sensors, the motor rotates until synchronization with motor poles), after the drive goes to state "enabled" the corresponding axis do a violent "jump". my theory is that linuxcnc counts the pulses from the encoder during initialization and when the drive is enabled it corrects the position.
so, how can I solve this?
Thanks,
João
Thanks,
João
- Thank you received: 4994
15 Jan 2014 00:50 #42773
What drives are you using? What type of motor?
Replied by andypugh on topic axis jumps on servo amp initialization
- jtc
15 Jan 2014 04:24 #42784
by jtc
Replied by jtc on topic axis jumps on servo amp initialization
granite vsd-e drives with 3phase ac servos (no hal sensors).
anyway, the problem was solved with a custom component that makes E-Stop permanent while initialization.
João
João
Time to create page: 0.048 seconds
