acessing to a system variable by a custom componet
- jtc
- Thank you received: 13
20 May 2014 03:25 - 20 May 2014 03:30 #47063
by jtc
acessing to a system variable by a custom componet was created by jtc
Hi!
I'ts possible to access to a system variable by a component? how?
the goal is read the Z position after touch off (I assume that this exists on a system variable)
this part of the component will be very simple, something like:
Thanks,
João
if(z==0)
out = true;
else
out= false;
Thanks,
João
Last edit: 20 May 2014 03:30 by jtc.
- Thank you received: 5013
20 May 2014 06:10 #47067
In a component written in C using "comp"?
Which "Z" do you want? If the value you want exists on a HAL pin then adding an input HAL pin is easiest.
Replied by andypugh on topic acessing to a system variable by a custom componet
- ArcEye
- Thank you received: 758
20 May 2014 15:37 #47082
by ArcEye
Replied by ArcEye on topic acessing to a system variable by a custom componet
Hi
halui.axis.2.pos-commanded (G53)
halui.axis.2.pos-relative (G54-5-6-7-8-9)
www.linuxcnc.org/docs/devel/html/gui/halui.html
to get the info from a hal pin-
#5223 for Z in G54
linuxcnc.org/docs/html/gcode/overview.html#sec:parameters
to get the info in gcode
#5223 for Z in G54
- jtc
20 May 2014 16:05 #47084
by jtc
Replied by jtc on topic acessing to a system variable by a custom componet
yes is a written C comp.
Thanks. with this info I think that will work.
João
João
Time to create page: 0.055 seconds
