10rpm Spindle Encoder
29 May 2014 03:21 #47482 by Poma
Replied by Poma on topic 10rpm Spindle Encoder
There is a way to software generate an index, iirc?
You would then need to export that pulse as an output to a hardware pin and back into the encoder counter..
Is this to prevent the error "motion.spindle-index-enable already has an output bitslice.0.out"?motion.spindle-index-enable is an I/O bit, whereas bitslice.0.out is an OUT.
Seems like a known bug? I don't understand why an OUT cannot be connected to this pin. How else does one get information into it?
29 May 2014 04:01 #47487 by andypugh
Replied by andypugh on topic 10rpm Spindle Encoder
It's not a bug, it's an (annoying) feature. If you connect an "out" to an "io" then the signal always takes the value of the out, so the "io-ness" is lost.
Have a look at linuxcnc.org/docs/html/man/man9/tristate_bit.9.html for one solution.
29 May 2014 06:04 #47491 by Poma
Works like a charm, thanks.
Except... index-enable doesn't work. I'll save that for another thread.
06 Jan 2015 23:19 - 06 Jan 2015 23:31 #54666 by Poma
Looking back through this I realize I didn't leave other users with a very good idea of my solution, if someone should ever need to do what I did. I'll put my chunk of code here and hope that is enough:
# Compute the spindle speed using derivative, multipy, and absolute functions
setp motenc.0.enc-02-scale 5220
setp mult2.0.in1 60
setp lowpass.0.gain 0.002
net spindle-position motenc.0.enc-02-position => lowpass.0.in
net spindle-position-lowpass lowpass.0.out => motion.spindle-revs ddt.0.in
net spindle-enc-rps abs.0.in <= ddt.0.out
net spindle-abs  mult2.0.in0  motion.spindle-speed-in  <= abs.0.out
# pyvpc.hal
net spindle-rpm-filtered mult2.0.out  => pyvcp.spindle-speed
As for the indexing, I finally added a prox switch to the low-speed side of the spindle to get the best accuracy.
Last edit: 06 Jan 2015 23:31 by Poma. Reason: Clarifications and simplifications
07 Jan 2015 02:37 #54681 by Poma
Actually, I would like some advice on my spindle encoder resolution, and I would appreciate any input.
Let's assume I will be threading on a 2-meter diameter drum. I have an index prox switch and a 1024 encoder on the drum. That gives 6.283m circum and when divided by 1024 is 6.136mm per encoder pulse. Actually, I think this is a 4x quadrature encoder and decoder, so I have 4096 pulses which gives 1.5mm per pulse. It will probably be running at 20 RPM max, which gives a 4x encoder frequency of about 1.4 KHz.
Does anyone think I need a better encoder in order to be threading at this diameter? Or do you think it should be sufficient?
Time to create page: 0.081 seconds
