Jogging two axes at the same time teleop mode
- narogon
- Thank you received: 14
29 May 2014 00:43 #47472
by narogon
Jogging two axes at the same time teleop mode was created by narogon
Does anybody know how to solve this sourceforge.net/p/emc/bugs/345/ ???
I have a non trivial cinematics machine with a joystick connected.
In joint mode using halui.jog.n.analog and using halui.jog.plus / halui.jog.minus it works for more than one axis at the same time.
However in teleop mode it only works for one axis and the result is a erratic movement when i use halui.n.analog or only one axis movement in case of plus/minus way.
Regards,
Nacho
Regards,
Nacho
- Thank you received: 4994
29 May 2014 01:21 - 29 May 2014 01:27 #47476
Which version of LinuxCNC are you using? A fix to this is more likely in the Joints_axes_4 branch than in the main branch, but I don't know it has been fixed in either.
[EDIT]
That file hasn't been touched since the bug report, so the problem probably still exists.
Replied by andypugh on topic Jogging two axes at the same time teleop mode
[EDIT]
Last edit: 29 May 2014 01:27 by andypugh.
- narogon
29 May 2014 01:31 - 29 May 2014 01:31 #47477
by narogon
Replied by narogon on topic Jogging two axes at the same time teleop mode
Last edit: 29 May 2014 01:31 by narogon.
- ftkalcevic
29 May 2014 14:04 #47507
by ftkalcevic
Replied by ftkalcevic on topic Jogging two axes at the same time teleop mode
I fixed my own local version that I use for experimental stuff, so I can't guarantee I didn't break something else.
github.com/ftkalcevic/LinuxCNC/blob/gwiz...mc/usr_intf/halui.cc
- narogon
29 May 2014 18:06 #47511
by narogon
A silly question. If I want to recompile only halui.cc
./cofigure
make
Is just enough?
./cofigure
make
Is just enough?
- narogon
29 May 2014 18:13 #47512
by narogon
With your halui.cc file i can't jog any axis in teleop mode.
- ftkalcevic
30 May 2014 03:02 #47528
by ftkalcevic
Hmmm. That's not good.
Did you take the whole file, or just the changes I made? My version is based on approx version 2.5
- narogon
30 May 2014 18:40 #47545
by narogon
I've fixed some parts of the code to send only one
for all the axis keeping the speeds that don't change in emc_set_teleop_vector
Now it works perfectly for me.
Here is my version of halui.cc
Regards,
Nacho
emcCommandBuffer->write(emc_set_teleop_vector);
Regards,
Nacho
Time to create page: 0.058 seconds
