Stop or SlowDown on external input
- piflixe
- Thank you received: 5
14 Jul 2014 18:25 #48761
by piflixe
Stop or SlowDown on external input was created by piflixe
Hi there,
I'm new to this forum so please excuse if I posted at the wrong spot an feel free to move the post do a better category.
We are currently working on a Laser engraving machine using stepper motors. For optimal reliability we would like to control the speed of the X and Y axis with an external sensor. Two szenarios would be possible:
If anyone has experience with this kind of application, I would be glad to know! I assume it could be a very basic functionality or easy to implement but I haven't found anything likewise in the documentation or when searching the web. We would have some financial ressources if a special implementation is needed and are willing to put it back in the opensource software.
Kind regards,
Felix
- digital HIGH / LOW Sensor: when Sensor is LOW, process job as usual, when Sensor is HIGH, stop X and Y axis with usual decelaration and wait for sensor to turn LOW, then accelerate and proceed as usual.
- analog Sensor (eg. 0 - 12V) : adjust speed of X and Y axis according to value on Sensor PIN. The mapping might not be linear. When a sudden value change occurs, no steps should be lost, this could also be achieved by an analog filter of the sensor signal
Kind regards,
Felix
- Thank you received: 1467
14 Jul 2014 18:54 #48763
Replied by Todd Zuercher on topic Stop or SlowDown on external input
See here in the manuals linuxcnc.org/docs/html/gui/halui.html
for #1
halui.program.pause (bit, in) - pin for pausing a program
halui.program.resume (bit, in) - pin for resuming a paused program
for #2 probably
halui.feed-override.scale (float, in) - pin for setting the scale for increase and decrease of feed-override.
for #1
for #2 probably
Hi there,
Kind regards,
Felix
The following user(s) said Thank You: piflixe
- Online
- Thank you received: 5015
14 Jul 2014 19:16 #48765
I think that the best inputs for this would be motion.feed-hold and motion.adaptive-feed.
www.linuxcnc.org/docs/html/man/man9/motion.9.html
Both of these need to be enabled with G53 and G52 respectively. If your system is not using G-code then a different solution would be needed.
Most systems use G-code, but it is possible not to, I got about 10% into a system for laser rastering that worked directly from a jpg.
What is the source of your 0-12V signal? If you are using the parallel port then it is easier to interface digital signals than analogue, and a variable frequency square-wave is the easiest to interface (into the software encoder counter). The same is true of many of the alternative interfaces, but some do offer analogue inputs.
Replied by andypugh on topic Stop or SlowDown on external input
digital HIGH / LOW Sensor: when Sensor is LOW, process job as usual, when Sensor is HIGH, stop X and Y axis with usual decelaration and wait for sensor to turn LOW, then accelerate and proceed as usual. analog Sensor (eg. 0 - 12V) : adjust speed of X and Y axis according to value on Sensor PIN. The mapping might not be linear. When a sudden value change occurs, no steps should be lost, this could also be achieved by an analog filter of the sensor signal
- piflixe
16 Jul 2014 05:12 #48821
by piflixe
Replied by piflixe on topic Stop or SlowDown on external input
Thanks for your quick reply! I think if reading an analog signal is hard to realise, we would start off with digital. Is there a documentation of how to get started with the hal interface? - I am quiet new to linux cnc and not especially good in programming. Would you be willing to help us with the inital setup? As I mentioned, we have some financial ressources and I think it would be more effective to have someone at hand who is familiar with linuxcnc.
- Online
16 Jul 2014 05:31 #48822
www.linuxcnc.org/docs/html/index_de.html
(Some of that might be in German, but most of it isn't).
The section on HAL is the part that it sounds like you are interested in, "HAL Introduction" but you will also find it useful to look through all the HAL component descriptions to see what they can do.
You would generally read an input like you souned to have with an "encoder" component in "counter-mode" and use the velocity signal in HAL to adapt the feed.
You might also want to consider attending:
doodle.com/qn5sr87e6atphk43
You could try:Thanks for your quick reply! I think if reading an analog signal is hard to realise, we would start off with digital. Is there a documentation of how to get started with the hal interface?
There is lots of free help available on this forum.Would you be willing to help us with the inital setup?
- cncbasher
- Thank you received: 288
16 Jul 2014 23:46 #48849
by cncbasher
can you explain your reason for this ? or the problem you are trying to solve ?
i have a number of lasers , and not had to resort to adjusting the speed in this way .
so i wonder if it is the style of explaination
any way let us know and lets see if we can solve your problem .
is this a height focus issue , or rasterising error etc
Replied by cncbasher on topic Stop or SlowDown on external input
Hi there,
Kind regards,
Felix
- piflixe
18 Jul 2014 04:03 #48906
by piflixe
The reason for this is that due to very limited laser power and fragile surfaces, we have to reduce engraving speed when laser is not "burned in". The surface is normally white, turning black when being burned therefore absorbing more light therefore a much higher engraving speed is possible. We can observe that process using the light being reflected.
- Online
18 Jul 2014 05:23 #48908
So, ideally you need something that produces a variable frequency digital pulse depending on light intensity.
It is probably possible to do this (somehow) with a photocell and 555 counter. An alternative would be to use an Arduino, either to generate a "tone" based on measured voltage, or hooked up via USB (that isn't real-time, but might be responsive enough).
Time to create page: 0.108 seconds
