advantages of supplying phase B to spindle encoder
31 Jul 2014 17:38 - 31 Jul 2014 17:40 #49336 by Zahnrad Kopf
Replied by Zahnrad Kopf on topic advantages of supplying phase B to spindle encoder
So I guess the general consensus is to leave it for now? Drew - if it turns out ( no pun intended ) that we want higher count disks and I need to make one you are more than welcome to one as well. Just let me know at that time. It's just as easy for me to make three or four as it is to make one, at that point. I would probably WEDM them to get the slots as accurately as possible, with as sharp an edge as possible, and each slot as narrow as practical.
Last edit: 31 Jul 2014 17:40 by Zahnrad Kopf.
31 Jul 2014 23:36 #49354 by drogge
Thanks Zahnrad! I wonder what the practical limit WRT to slot count on a 3" disk with an off the shell optical switch is before one starts reading more than a single slot? The switch that Andy referenced has a dectector aperture diameter of .06" or 1.5mm. One could increase the dia of the disk I guess. US Digital sells a 2" dia 100 CPR / 4000 PPR optically printed disk for $42. The corresponding read head is another $42. Or you can get the whole thing in a case for $131.
Do you have your own wire EDM? That must be a cool tool to have access to. I'm currently lusting after a 40W desktop laser.
Drew
01 Aug 2014 00:00 #49355 by Zahnrad Kopf
Drew
Drew,
You're welcome. I ask for help all the time, here. If I can repay that help given in some small way, I'm all for it. Yes, I imagine we have some room available to us should we want to increase the disc size. I have to look, though. If you brighter guys want to figure out the best way forward, I'll help with what I can, here. :) Yes, we have WEDM. Actually, I have a whole shop. It's what I do. www.thegearmaker.com One would think I'd want to get as far away as possible at the end of the day, but truth is - it's my avocation as much as my vocation. I love what I do and do it for fun on my own time, too.
01 Aug 2014 07:27 #49365 by andypugh
Any idea what that will cut? I had these made by a local company that specialises in solder stencils for PCB manufacturers:
picasaweb.google.com/lh/photo/izs9EehSiB...pFm0?feat=directlink
They are to suit this (tiny) sensor: uk.rs-online.com/web/p/photodetector-amplifiers/7160604/
01 Aug 2014 08:27 #49368 by Zahnrad Kopf
Ack. I forgot that the new site isn't up yet. There's better pics on Instagram. American Machine & Gear Works
01 Aug 2014 08:33 #49369 by Zahnrad Kopf
Wow. Holy Mini Multi Apertures, Batman! That's sweet, Andy. Did you get it paired up with the reader yet?
01 Aug 2014 12:16 #49376 by drogge
Andy, I'd never heard of surface mount opto stuff. That's pretty amazing. What's the dia. and line count of is the wheel? Was it laser cut or etched. 40W is pretty much hobby stuff. 1/4" plexi and plywood.
Zahrad, That shop's yours? That's some pretty nice stuff! If you don't mind my asking, where are you located?
01 Aug 2014 17:49 - 01 Aug 2014 17:51 #49386 by Zahnrad Kopf
Drew - Yes. Tropical Milwaukee. When I was writing of the encoder disc, this is the part I had in mind.
Those inside radii are .012" if I recall correctly ( been a while ) and the material was .006" thick.
Last edit: 01 Aug 2014 17:51 by Zahnrad Kopf.
01 Aug 2014 18:11 - 01 Aug 2014 18:14 #49387 by andypugh
Yes, picasaweb.google.com/lh/photo/kWSTOh9MUU...pFm0?feat=directlink
Unfortunately the reflective sensors are very sensitive to distance (transmissive sensors are very much to be preferred, and also available as surface-mount 3mm cubes) and one of the encoders counts unreliably and that project found its way to the back of the shelf.
Last edit: 01 Aug 2014 18:14 by andypugh.
01 Aug 2014 18:14 #49388 by andypugh
75mm dia, 50mm centre hole, 75 lines per inch. I think it is 512 slots / 2048 counts, but I might be wrong.
It was to go on this:
picasaweb.google.com/lh/photo/1gX6p3sVta...pFm0?feat=directlink
Time to create page: 0.136 seconds
